Aorus 17G YD laptop, broken display, could not switch to external monitor
  • ArchangelGabriel
    • Feb 2022
    • 37
    • Romania
    Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have 3.3v, if I press it, the laptop awakens, power on led on, fan spins, cooler warms, the rgb led from the keyboard lights, and I get display backlight on. On the display connector I have 19v, 3.3v present etc. Ive tried to connect an external monitor on HDMI or mini DP ports and from the keyboard I press Fn and F5 to toggle from internal to external display but I get no picture from the external monitor. I plugged an external keyboard, and I get caps lock and num lock toggle. What sould I try more to get picture on the external monitor so I can know that the laptop is good and after that, buy the replacement display and maybe the case. Thank you!
    LE. I've managed to unlock the battery, some of the cells were over discharged, and the thermal fuse was melted, now I have charging led on, and if I unplug the charger, the laptop stays on! I've measured the eDP connector (40pin) in resistance mode and in diode mode, with internal display attached, stdby and pwron and I get like this: 1-Stdby OV pwron 1.72V ,2,3,4,5-OV(probably NC) , 6-3.3V , 7,8,9-gnd , 10,11,12,13-19V ALW, 14,15 gnd, 16, 17-3.3V, 18 without display I get 0.024V with display and pwron I get 2.94V, 19-gnd, 20,21,22,23-3.58V ALW, 24-gnd, 25,26-0.59V pwron, 27-gnd . 28,29-0.022V, 30-gnd, 31,32-0.022V, 33-gnd, 34,35-0.022V, 36-gnd, 37,38-0.022V, 39-gnd, 40, only resistance 1.2K
    From 25 to 38 there is eDP pairs,probably 25 si 26 eDP AUX line and the rest eDP data line. No eDP AUX and eDP data line is shorted to ground. The arrangement of pin is al litlle strange, because the panel is without microphone and camera, it have 300Hz refresh rate, I think no pwm backlight adjustment. etc.
    So, how do I get the laptop to toggle from internal display to mEDP external port or HDMI port, from FN-F5 combination key from keyboard? Sorry for the long post! Thank's!
  • ArchangelGabriel
    • Feb 2022
    • 37
    • Romania
    Just a quick follow-up, the backlight does not start anymore, initially motherboard draw 40mA, now only 20mA. Still no shorts on eDP conector, but I am missing some voltages which where present before. When I was probing some pin from eDP connector I've touched 2 pin, it was a small spark and after that I get no voltage on pin nr.16 which was 3.3V. I am tot worried about CPU and GPU, al their data lines to eDP are AC coupled but PCH is my concern. So, maybe I could not get the schematic for this laptop but maybe I could get something similar or close enough. I7, 11GEN, RX30, HM570 PCH, most important, 40pin eDP connector, full HD, 300Hz, no touchscreen, no camera, no mic, I know there are some models whith similar configuration. I am trying to determine the connections between PCH and eDP connector. Any help will be greatly appreciated! Thank you!
    • ArchangelGabriel
      • Feb 2022
      • 37
      • Romania
      Very strange design, very strange marking, check this Click image for larger version
      • ArchangelGabriel
        • Feb 2022
        • 37
        • Romania
ID:	3156585 this should be 1.05alw, I think!
        • ArchangelGabriel
          • Feb 2022
          • 37
          • Romania
          With dc-in I could not find 1.05 3.3v and 5v alw, but I have 3.3 on pwrbtn, if I pres it, the mainboard awake, etc. Click image for larger version
ID:	3156589EC, I could not find datasheet!
          • ArchangelGabriel
            • Feb 2022
            • 37
            • Romania
            1.8v I think Click image for larger version
            • ArchangelGabriel
              • Feb 2022
              • 37
              • Romania
              Without schematic, almost impossible to repair!
              • ArchangelGabriel
                • Feb 2022
                • 37
                • Romania
                More marking Click image for larger version
                • ArchangelGabriel
                  • Feb 2022
                  • 37
                  • Romania
                  More Click image for larger version
                  • ArchangelGabriel
                    • Feb 2022
                    • 37
                    • Romania
                    I found some testing point, sorry to bother! From what I see all are active high so I should have 3, 3V on them when the laptop is awake and running? Thank you! Click image for larger version
ID:	3157392 Click image for larger version
ID:	3157393 Click image for larger version
ID:	3157394 Click image for larger version
                    • ArchangelGabriel
                      • Feb 2022
                      • 37
                      • Romania
                      more
                        by momaka
                        03-15-2023, 10:17 PM
                        Gigabyte AORUS AORUS 15-WA Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 15-WA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15-WA boardview and AORUS 15-WA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 09:00 AM
                        Gigabyte AORUS AORUS 15-XA Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 15-XA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15-XA boardview and AORUS 15-XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      • fasda1984
                        GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died
                        by fasda1984
                        , Hello have same GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died without crash or something, just started in black screen, checked driver in devices and have only external display, no more internal... Any suggestion? External working fine, no problems no errors
                        06-22-2024, 01:43 AM
                        Gigabyte AORUS AORUS 15P XD Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AORUS AORUS 15P XD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15P XD boardview and AORUS 15P XD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 05:00 AM
