hi guys i am new to this forum. but i hv seen many useful posts here.
First of all i hv moderate knowledge in electronics. Therefor i repair notebooks for fun n for my pocket money.
last week my friend brought me a laptop with following symptoms:
HP 630 Core i5 with Chicago_HR_HPC
When i plugged in charger DC jack lights on
after pressing power power light turns on but nothing else.
no fan , no display ,no thing other than lighting up power led laptop seems almost dead.
According to the power sequence:
3.3vAL/5vAL and 3.3vA/5vA lines up n running
PWR_SWIN# -- ok -- lights up
RSMRST# -- 3.3V (always shows 3.3v no change when pressed power button)
EC_PWRBTN# - 3.3v/0v (it shows 3.3v before pressing power button after it shows 0v)
SLP_S5#_3R - ? (schemetics says it is the next thing to check which says sending S5 signal to SB to EC)
SLP_S4#_3R - nothing
SLP_S3#_3R - nothing
from that point everything stops.
Therefore i assuming that BIOS chip doesn't involve in this case Bcz it wont power up whereas S3# signal not coming out from south bridge.
I want to knw is this voltages are ok and how to check S5.
Also i hv already reflowed south bridge to make sure HP laptops south bridge problem is not the reason for this problem.
i think EC (IT8518) is bad bt before i replace it i want to knw what you guys suggesting ......
thanx .....................
