ibm R50e password locked
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    does anyone have idea about ibm bios password.
    my ibm R50e wants to put a password in black screen in booting time.
    what to do?
  • Alfa is auto
    • May 2013
    • 83
    • Finland
    Re: ibm R50e password locked
    There is atmel bios chip..you can buy it from ebay and it got newest bios on it but i ve been shorted pin 5&6 or was it 4 when the pc start short those and voila.its unlocked...cant remember now but google atmel chip and ibm r50
    • Alfa is auto
      • May 2013
      • 83
      • Finland
      They are SDA&SCL pins so short those when you light up the pc ,it may take up to 10min cause youre reaction time is crucial
      • dycc
        Vision
        • Nov 2011
        • 624
        • Côte d'Ivoire
        that is absolutely not true . short those pin may lead to damage the lapy.
        check this link . http://www.allservice.ro/forum/viewtopic.php?t=47
        • dycc
          Vision
          • Nov 2011
          • 624
          • Côte d'Ivoire
          https://www.badcaps.net/forum/showth...ghlight=24rf08
          • Alfa is auto
            • May 2013
            • 83
            • Finland
            It is your opinion but i ve been succesfully remove bios locked from t60-61 (4)pieces,yes you can ruin the hole lappy but dont keep those wires too long together.
            • Nopslide
              HP Omen 15-dh0052nf power-on & bios password
              by Nopslide
              Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
              My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
              Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
              04-01-2024, 04:27 PM
            • moshu
              HP EliteBook 755 G4 bios password locked
              by moshu
              Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
              I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
              Can you please help to remove the password?
              after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
              HP EliteBook 755 G4
              ProdID: W5Q98AV
              SN: 5CG7524BY4...
              02-01-2025, 06:59 AM
            • Modify_inc
              Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
              by Modify_inc
              I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
              11-02-2021, 11:14 AM
            • Mike_Ho
              ThinkBook 13S G2 ITL password locked need Help !
              by Mike_Ho
              Dear All,
              I have one 2nd hand Thinkbook 13s G2 ITL with broken display, after replace the LCD module it show password locked ,
              Can someone please kindly help me to get back the password code or modify this BIOS Dump to clean the password.
              S/N: R912D81K
              BIOS: W25R256JV
              Thank's a Lot.
              Best Rgds,
              Mike....
              07-13-2023, 09:20 PM
            • outsider
              Panasonic FZ-G1 MK5 - BIOS password returning
              by outsider
              Hello
              I removed the BIOS password thanks to the help of one of the friends of this forum.
              https://www.badcaps.net/forum/troubl...61#post3637661
              The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
              06-17-2025, 12:51 AM
