HP DV5000 Power LED Blinking
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Does anyone has any idea that if HP DV-5000 Power LED blinking and nothing appear on display, and not power's on properly which part is faulty? I reflow VGA chip and Intel Power Controller chip but the problem is still there. . . I'm very upset because the customer is eating my head daily. Because it wasn't like this but when i opened it the problem was just appeared. And still never be sorted out. . .
    What should i do?
    plz help me out.
  • Momad
    • May 2013
    • 24
    • ITALY
    Re: HP DV5000 Power LED Blinking
    First do reset HDD, tack out the Battry, power cord from the Laptop & the wall, then press power button for 1 minute and Tray without battry
    Check the voltage at Power Supply, and power socket (DC jack) and controll the cord of power supplay .
    When led blinking, the battry is out? If not tack out the Battry.
    try all controlls without the Battry. when you have found the solutions controll with Battry for controll the charge process.
    Try to change Ram and CPU. Good luck!
    • Momad
      • May 2013
      • 24
      • ITALY
      Ih, if the reset HDD is negative try to tack out The CMOS battry for abuot 1 Hour. without battry and power supply.
      • jtamad44
        • Apr 2013
        • 145
        • israel
        What should i do?
        plz help me out.
        If the cap lock led blinkin, change the gpu chip.
        If the dc jack led blinkin, reflash or change the bios ic.
        • fddizon
          • Sep 2011
          • 555
          • Philippines
          hi,
          if i were you, here is what i'm gonna do.
          1. recall what you have done to the unit just after the unit is working fine. the parts you removed, the procedures you made etc.
          2. from there, examine the parts you touched. maybe you did something that when you return it, it was not well seated or not connected firmly. or maybe youdid more than that, short something on the circuit to make it that way.
          3. make necessary adjustments/correction observing proper procedure of repairing.
          hope this helps
          good luck
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            id like to add on jtamad44,
            if those LEDs are blinking (Caps and Num Lock) see HP troubleshooting guide of the blink codes. you will determine which part is at fault with those blink codes.
            regards
            • Techie666
              • Feb 2013
              • 23
              • Mexico
              regards
              http://h10025.www1.hp.com/ewfrf/wc/d...name=c01443366
              • dj_ricoh
                • 2073
                • uk
                i had a dv5000 and it was working fine on external display, i try to change the inverter and i connected (1% to find) a bad inverted. now it will not power, just power blink.
                maybe something similar happen to that notebook that was done and got in that situation
                • Momad
                  • May 2013
                  • 24
                  • ITALY
                  There is pad connection of power to LCD socket on the Motherboad, try to controll PWM_INVERT circuit line, VCC of LCD lines at socket and first (IC's, capacitors and mosfet) af power LCD.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    03-31-2024, 02:12 PM
                  • ronaldo17
                    Power button blinking, Laptop Hp pavilion gaming 15-ak DAX1PDMB8E0 rev E
                    by ronaldo17
                    When I press the power button, nothing happens. All I can see is the power button blinking and never stopping.
                    Here’s everything I’ve tried:
                    -Removed the battery
                    -Changed the power adapter
                    -Replaced the CMOS battery
                    -Changed the RAM.
                    But my laptop is still blinking. However, in the morning after I wake up, the laptop will turn on.
                    Here is my spec:
                    -i5 6300hq
                    -Gtx 950m
                    -Hp pavilion gaming 15-ak030tx Laptop DAX1PDMB8E0 Rev E
                    Now, I'm trying to fix the motherboard using the schematic I found
                    If anyone can help...
                    08-25-2025, 09:02 PM
