dell inspiron L502X NO POWER
  • guruji
    • Oct 2012
    • 118
    • India
    hello,
    i have a dell insp l502x board no quanta DA0GM6C i have only stdy voltage +3.3v coming from tps51427 dc/dc the +5v is absent due to alw_on signal not there.i have checked the 3.3v login power on no problem there changed the micom ite8518e. I have doubts with the ec bios can anyone upload the dump for it.also does the ALW_ON come from the micom after power switch pressed or it is present always.anyone faced power issue with this laptop. pls helpp
    thanks
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: dell inspiron L502X NO POWER
    i have the same computer with bios password . i can upload the ec dump . will do it tomorrow but i need also yours (4Mb spi rom dump and 512kb ec dump)
    • guruji
      • Oct 2012
      • 118
      • India
      no problem does yours power on i will anyways upload for you the bios and ec pls check and let me know.
      thanks
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        yes mine is working .just password on boot
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          today will dismantle mine and will let you know If alw_on is always present or come after pressing power button .
          • guruji
            • Oct 2012
            • 118
            • India
            ok thanks meanwhile i am attaching the bios and ec.this one is without password but pls check the bios and tell me.
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              ok will let you know today
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                wow wow wow wow wow wow wow wow wow wow wow wow wow it work fine the 4Mb dump thank you very very very very very very very very very much guruji thanks again.
                now for your faulty board notice that the ALW_On is always present when you plug the adapter . before pressing the power switch button you must get 3.3v and 5v . i think if you don't have 5v you must check arrond coil if there are no short or the tps51427 is dead
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  the ec dump is also good . sorry forgot to tell you
                  • guruji
                    • Oct 2012
                    • 118
                    • India
                    okay that good pls can you click a good photo around the ite8515 as i think someone have removed some resistors. so i can see if any missin parts.
                    thanks
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • Côte d'Ivoire
                      do you have the diagram
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        • guruji
                          • Oct 2012
                          • 118
                          • India
                          yes i do have the schematics i am not getting alw_on does it come from the ec
                          • guruji
                            • Oct 2012
                            • 118
                            • India
                            can you send me a photo of the components around ite8515e as i feel something missing
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              have already screw the lapy. but notice that only with battery the alw_on signal come after tou press the power switch button . but with adapter the alw_on signal is already present when you plug it
                              • dycc
                                Vision
                                • Nov 2011
                                • 625
                                • Côte d'Ivoire
                                EC pin 83=alw_on = 3.3v
                                • dycc
                                  Vision
                                  • Nov 2011
                                  • 625
                                  • Côte d'Ivoire
                                  ec=ite8518 not ite8515
                                  • dycc
                                    Vision
                                    • Nov 2011
                                    • 625
                                    • Côte d'Ivoire
                                    tps51427=isl6237=rt8206b
                                    first check ONLDO signal pin4 of tps51427 onldo=+PWR_src*(pr122)/(pr121+pr122)
                                    then check LDO signal pin7 of tps 51427 LDO=+5v_ALW2
                                    the LDO signal activate +3.3_en1 an +5_en2 to provide +3.3v_ALW and +5_ALW
                                    • guruji
                                      • Oct 2012
                                      • 118
                                      • India
                                      Hi i have replaced the tps51427 also a new micom ic.i get all the voltages accept the +5v alwp.will check if there is a short in the 15v-alw.will check tomo anyhow
                                      Thanks again for your help.
                                      • mohamed.mostafa
                                        • Sep 2012
                                        • 40
                                        • egypt
                                        thanks dycc , guruji for sharing your files .
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
