Acer D150 resistor replacement
  • spleenharvester
    • Mar 2010
    • 921
    Hey all. Got a motherboard here with a faulty 4407A MOSFET (to be replaced by a 4407 shortly) and a blown SMD resistor.
    The resistor is marked on the schematic as being 0.05ohm, 1206 size, 1% tolerance.
    I cannot find a single 0.06ohm resistor in 1206 size on any of my scrap boards. I've found a few "0ohm" 1206 1% resistors but no 0.06ohm.
    What possible values can I replace it with?
    Cheers!
    EDIT: Forgot to mention the most important part haha. It's right on the VIN line, check: http://i.imgur.com/g9wfRDF.png It's PR56.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spintop
    • Feb 2011
    • 132
    Re: Acer D150 resistor replacement
    0 ohm is fine too.
    • spleenharvester
      • Mar 2010
      • 921
      Think I'll just use that then. What even is the point of a 50mOhm resistor in a circuit like this, just out of curiosity? Will 0ohm last long term?
      Cheers!
      EDIT: https://en.wikipedia.org/wiki/Zero-ohm_link
      You learn something new every day haha. Hopefully it worked if it's there as a low-cost fuse, since I can't see anything blown beyond that point.
      Cheers!
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        Cheers!
        You get R = 0.05 ohms or 50 milliOhms, Voltage drop across this R is say 0.5V or 50mV. What would be the current flowing through it?
        I = V/R = 0.5/.05 = 10 Amperes.
        In charger circuit (ISL6251 for example), it is used to regulate AC adapter current (CSIP/CSIN pins) together with the ICM pin.
        • spleenharvester
          • Mar 2010
          • 921
          Update on this board, replaced the MOSFET and resistor, still no go. Completely dead, shorts reading all over the place. A lot of the crap connectors on this board melted as soon as I brought the heat gun near so I'm going to stick it in the scrap pile.
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
            09-06-2024, 05:27 AM
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
            09-07-2024, 05:00 AM
            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
