Super I/O chip, on/off pins
  • LiquidCap
    • May 2013
    • 21
    • us
    One day while poking my probes around on a laptop's super i/o chip I discovered i can turn the laptop on/off by shorting the right pins. My question here is can this be done with every super i/o chip one every laptop?
    Another question: Can this be done the same way with desktop motherboards also?
  • RobRocks
    • 13
    Re: Super I/O chip, on/off pins
    Hello, the i/o chip offers different levels of power on, lets say power states, you can see this from the schematic, the s3, s4, s5 which will give power to certain ic`s. the s5 is the full power on, the other ones can be charging, standby and some other functions. By injecting 3.3v to the right pin of the i/o ic you activate the different levels, check the schematics für the right pins. But if the bios is damaged, even if you inject the voltage the screen will not come. Lets say you activate the s5 level and all voltages to all ic`s are there, if the bios or the i/o ic still has a problem, picture will not come.
    • Francisco.s
      • 686
      • Spain
      How to know the right pins?
      It is very difficult to say, there are so many different laptop.
      • japlytic
        • Oct 2005
        • 2086
        Many chipsets have General Purpois Input/Output (GPIO) pins, of which use is at the discretion of the motherboard manufacturer.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          Yes you can. Just check the schematic, your on/off button connected directly to the io chip.
          • nevenne
            • Jan 2024
            • serbia
            You can turn on the computer at the keyboard connector usually first 2 pins from the right side.https://www.youtube.com/watch?v=j8q4eEcKRDU
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • ongobongo
              Asus ROG Ally - Super IO Chip replacement
              by ongobongo
              anyone here who has experience with replacing the super IO chip of an ROG ally?
              I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
              Ongo
              11-17-2024, 11:27 AM
            • chickenhawk88
              Preflash Super IO chip
              by chickenhawk88
              I was wondering if you guys know anyone that sells Super IO chip ITE IT8390-256 flashed with your specific laptop. Im debating to see if this available out there vs buying chip and programmer myself. Right now the chip plus programmer is about $60. But i still need the file that goes on chip. The laptop is RAZER BLADE 15 RZ09-0369.
              05-19-2024, 01:22 PM
            • MasEkapses
              Super IO Chip ENE KB9542qe
              by MasEkapses
              Hello everybody, i am diagnosing a hp omen 15-dh0007ng motherboard with no power. After a bit messuring I found out that the 3v rail is missing. Looking after that I found a short on a cap on an step down regulator ic. After removing the cap the short was still there. I also removed the ic looking if maybe this is internally shorted. The short remained still there. After that I tried to inject voltage 3.0v on the 3v rail and I found through thermal camera the super iO chip heating up. It had a current draw of about 0.7A. Now I want to replace the super iO chip but I found out that they contain...
              07-13-2024, 06:56 AM
