dell 1545 ac adapter problem
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    hi every one . I have a Dell Inspiron 1545 and I used to get an error message saying something about using a genuine Dell adapter? my ac adapter type cannot be determined and something about a 65W AC or higher for best operation. Easy way to fix it is by calling dell. i change many charger & battery but same error coming
    please help me to solve this problem
  • alihomee
    • Dec 2012
    • 1577
    • malaysia
    Re: dell 1545 ac adapter problem
    you can disable this opption in setup by pressing f2 or you should use the dell 65w orignal adapter.
    • rievax_60
      • May 2012
      • 897
      • australia
      I had that trouble lately after replacing the keyboard controller IC in a Dell 1545 which was damaged by someone fitting the wrong LCD screen.
      The keyboard controller IC communicates with a "1-Wire" IC in the charger via the center pin of the charger's DC plug. The positive power connection is the inner surface of the plug's sleeve.
      In the charger there was a protection zenner across the 1-wire IC and a series resistor, I cant remember the exact value, a few hundred ohms I think.
      I found that I had solder bridged some pins of the new keyboard controller IC.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        go in to setup and disable the option about charger.
        • innocentforeign
          innocentforeign
          • Jun 2013
          • 172
          • KSA
          thanks all
          dear rievax system give error not charging i check the resistor , show value 100k in schematic give 33 ohms i change the resistor check all zenner diode P.Q are good also change keyboard controller IC but same problem coming
          • bw4ali
            • Jun 2013
            • Pakistan
            Dear,
            kindly change your keyboard ic because its on leg is connected with charger pin.
            othervise you must change your MAX ic.other i am here for your help.
            • rievax_60
              • May 2012
              • 897
              • australia
              thanks all
              I would have left that resistor alone. Resistors dont change like that.
              I remember there was some complicated circuitry along the signal path which included some MOSFETs. I think its protection for the keyboard controller IC incase 19 volts gets applied to the center hole of the DC socket.
              There is a place on the small PCB near the DC socket where I see the 1-Wire data on my DSO. There is only one brief burst of data when the charger is first plugged into the laptop.
              • rievax_60
                • May 2012
                • 897
                • australia
                thanks all
                I was using this schematic,
                Does it show the resistor?
                • innocentforeign
                  innocentforeign
                  • Jun 2013
                  • 172
                  • KSA
                  yes dear resistor id is (R91) and it is before FET (q6)
                  connected with keyboard ic (u20b) leg no 63
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    What value is R91 now?
                    What total resistance do you measure between pin 63 of the KB IC and the center hole of the DC socket?
                    • innocentforeign
                      innocentforeign
                      • Jun 2013
                      • 172
                      • KSA
                      thanks for support dear first i change used ic but its give same problem . now after change a new u20 keybord ic charger working good and charg the battery thankyou agin for help
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        OK, good.
                        Although I still think that the purpose of Q6 is to protect the KB IC from spikes, I dont think it gives good protection because the circuit shows a 33 ohm resistor between Drain and Source.
                        Spiked pins usually measure some low resistance to ground or to supply rail.
                        • innocentforeign
                          innocentforeign
                          • Jun 2013
                          • 172
                          • KSA
                          you are right thanks a lot
