Pavilion dv9000
  • crdz66
    • Nov 2012
    • 242
    Pavilion dv9000
    Hi Fellas.
    I have a problem with my DV9000 hp pavilion laptop.
    This laptop once push the button once for turn on, turn on-off 4 times and after that the laptop runs good without problem.
    What do you think cause that?
  • heavymachines
    • Mar 2011
    • 1028
    Re: Pavilion dv9000
    Originally posted by crdz66
    Hi Fellas.
    either sticking power button or power button ribbon is going out or its a early sign of needing a reflow..... one of those three most likely...
    • crdz66
      • Nov 2012
      • 242
      Re: Pavilion dv9000
      Ribbon cable is brand new
      After turn on-off the computer working good for long time.
      Power button not feel sticky.
      But thanks for you comments.
      • heavymachines
        • Mar 2011
        • 1028
        Re: Pavilion dv9000
        let me clear it up the power button does not need to be "sticky".... internally they get contact powder and carbon buildup and when there is a buildup it can cause a stuck button like behavior where it will power on then back off just like what your experiencing and after few tries it will take off you can take theses little button apart and clean the carbon out and put it back together done it many times and there same button used in many mouse pads and the left clicker is common to go out on them....cleaning it fixes the problem every time on a dead mouse "touchpad" clicker...or inconsistent clicks...
        there is a cage on the top you can carefully desoldier and take the guts of it out and clean the black buildup on the contacts and carefully put it back together and resoldier the cage back on don't over heat it and melt the plastic....good luck... its tiny work...
        • gijoey198079
          • Dec 2012
          • 53
          Re: Pavilion dv9000
          If that don't do it probably def need a reflow. I have seen a number of these boards where the GPU or Southbridge needed reflowed, some issues was power, blank screen or scrambled video, boot with no fan, no wifi, not reading optical drive, and the list goes on. A quick reflow of both GPU and southbridge will most likely fix the problem but it's not a permanent fix unless you completely reball and add copper shims on the heatsink.
          • salman
            • pakistan
            Re: Pavilion dv9000
            i think that,s his bottan problam you can do tha servis of this bottan or change it thanks
            • nish_pinto
              The Adventurist
              • Oct 2011
              • 83
              • India
              Re: Pavilion dv9000
              Need to clear some doubts here. Not heard much of relfowing the Southbridge. However, if there are problems associated with southbridge, are you saying that reflowing the southbridge will clear all those problems?
              http://nishantpinto.blogspot.in/
              • crdz66
                • Nov 2012
                • 242
                Re: Pavilion dv9000
                Thanks all comments.
                Let me be clear on something.
                The power button was pushed only 1 time.
                I don't push the button 4 times.
                The laptop turn on-off like loop until start normaly.
                • opamp
                  • Dec 2012
                  • 160
                  • united states
                  Re: Pavilion dv9000
                  Try flashing the bios and reflowing gpu.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    Re: Pavilion dv9000
                    yep its an early sign of reflow issue.......reflow and test if works... reball.. gpu and or southbridge welcome to hp dv series they ALLL are affected from dv2000 all the way to dv9000
                    • gijoey198079
                      • Dec 2012
                      • 53
                      Re: Pavilion dv9000
                      I've only had to reflow the southbridge once and that was due to a wifi issue on a dv6000.
                      Relow will NOT always clear these problems, in most cases it can but I have seen many that needed to be completely reballed .
                      From my experience, the video and power issues on these boards are most of the time issues of the GPU and thus fixed by reflow or reball.
                        HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                        09-12-2024, 03:44 PM
                        HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                        This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                        This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                        This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                        This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
