X51RL dead
  • lord
    • May 2011
    • 319
    • Croatia
    X51RL dead
    It is dead, no reaction what so ever.
    3V3 and 5V present, power button has some voltage, in think 3V3, a tried to reheat with hiot air both southbridge and northbridge, but there is no change.
    Anybody had a same problem with this unit?
    TNX in advance!
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: X51RL dead
    could be a dead processor!
    • lord
      • May 2011
      • 319
      • Croatia
      Re: X51RL dead
      I didn't thought it is a CPU, but i tried it anyway. No difference.
      But i noticed that the + pin of the CMOS battery has no voltage. Perhaps that could be a clue.
      Does anybody has a scheme of this laptop?
      • lord
        • May 2011
        • 319
        • Croatia
        Re: X51RL dead
        Bump!
        I could use a scheme :|
        • artois7
          • Mar 2011
          • 159
          Re: X51RL dead
          I can't help but I've had one of these sat about for ages, must have a short as it makes the adapter blink the second it's plugged in.
          • lord
            • May 2011
            • 319
            • Croatia
            Re: X51RL dead
            Anybody? Could it be IT8511TE? There is no +3VA on CMOS battery...
            • Hemingray
              KABOOM!
              • Jul 2010
              • 143
              Re: X51RL dead
              Did you replace the battery?
              • lord
                • May 2011
                • 319
                • Croatia
                Re: X51RL dead
                There is no battery at the moment
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: X51RL dead
                  Definitely true if there's power. Especially only LEDs, fans and HDD spinning.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • double_DD
                    How can I be sure that my EC chip is dead?
                    by double_DD
                    As the title suggests, how can I be sure that my EC chip is really dead?
                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                    03-12-2025, 07:47 AM
                  • disorder
                    ps5 edm-033 dead after hdmi/usb ports destroyed
                    by disorder
                    hello guys,
                    i need help to repair a edm-033 ps2
                    history : as always hdmi port and usb ports destroyed after unplugged
                    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                    so i changed it
                    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                    i don't see any projection of liquid metal on pcb.
                    01-14-2025, 12:48 PM
                  • Beton
                    Finding a dead short component
                    by Beton
                    Hi guys!
                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                    I have a bench PSU and if I try to inject voltage the voltage...
                    12-10-2021, 01:05 PM
                  • zunasthegreat
                    Chieftec GPS-450-AA with dead 20N60C3
                    by zunasthegreat
                    Hello everyone hope all doing well!
                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                    09-01-2024, 07:12 PM
                  • FiguringITout
                    MSI Raider GE75 - Not posting, probable dead CPU
                    by FiguringITout
                    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                    07-25-2024, 07:27 AM
