help me problem with laptop toshiba a200
    please help me problem with laptop toshiba a200 login windows after 5 minutes freeze, after freeze lamp indicator hdd dead. thank before
    Re: help me problem with laptop toshiba a200
    Have you tried a new hard drive?
      has been replaced with a new hard drive still will not work
        Most likely over heating. Is the fan working?
        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
          fan works fine, but there is something not working properly, the working voltage in nec Tokin always changing.
            If it's software monitoring, don't trust it it's pretty much useless. Sounds like it could be bad RAM. Take out 1 stick of RAM at a time and see if it stops freezing. It doesn't blue screen or anything?
              +1 to what pentium 4 said.
              Download memtest, burn to disc and boot it up, run it for a while and see if you get any errors.
              If not it still may be over heating.
              Does the fan come on at full speed?
                since you've isolated you HDD already, it is time for the RAM. try memtest.
                Virus and malware may also cause this issue so your antivirus, malwarebytes and ccleaner may help you in that area.
                  hank you all, problem solved case closed
                    Good to hear! What was the issue?
                      Please we are trying to help ourselves here , that is why we are on this forum,so if you solve a problem please let us know what you did so as to help others with similar issues.
                        That is normal, its to do with the way the CPU reduces power consumption.
                        Does the A200 run longer when powered just from battery?
