HP 6730s no backlight
  • rdb89
    • Jan 2012
    • 10
    Hi there, i'm trying to repair an hp 6730s w/o backlight. I try the display and the inverter with another notebook and they work. Now i was measuring voltage with a multimeter. The invterer has 7 input pin.
    I've got:
    pin 1: 19v
    pin 2: 19v
    pin 3: gnd
    pin 4: gnd
    pin 5: 1v
    pin 6: 0.01v
    pin 7: blank
    On pin 5 i originally have a voltage of 3,3v but after some test the voltage fell down to 1v. How can i solve this problem? The voltage on pin are "right"? Thanks and sorry for my english
  • lord
    • May 2011
    • 319
    • Croatia
    Re: HP 6730s no backlight
    Every inverter has 5 pins. 19V, GND, PWR and DIM. Try to find datasheet of the IC on inverter and try to identify which pin is PWR and which pin is DIM.
    Then bring 3.3V-5V on pin that is for PWR, and 1,5V-2,5V on the DIM pin. The inverter should work.
    I had one sony that had a problem with the inverter, couldn't find the error on the motherboard, so i connect the volatges manually. Everything is OK, just the backlight doens't shut down when laptop going to sleep, which wasn't a problem at the moment.
    • rdb89
      • Jan 2012
      • 10
      This is my situation at the moment
      Anyone can help me?
      • lord
        • May 2011
        • 319
        • Croatia
        Didn't you understand my post on what you must do??
        • rdb89
          • Jan 2012
          • 10
          Ok, thanks for the reply. Where i can take this voltage from the motherboard?
          • lord
            • May 2011
            • 319
            • Croatia
            From USB
            • lucco85
              • Feb 2012
              • 20
              • Hrvatska
              From USB you can take 5v, you need 3vs
              Can take from q36(FDC655BN)
              • lord
                • May 2011
                • 319
                • Croatia
                rdb89 - if you have a multimeter search the board for the voltages you need. It is not that hard.
                And i would check the inverter cable for broken leads.
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  tu n'a qu'a suivre les lignes qui relient le pin 5 et 6 a la carte mère . généralement elles aboutissent sur le drain ou collecteur de transistors utilisés pour la commutation. tu n'aura qu'a les supprimer (les transistors) et récupérer la tension a la source ou l’émetteur du transistor concernés et le shunter directement au drain ou collecteur.en gros on supprime les interrupteurs commandés pour les remplacer part des court circuits . "l’inconvénient" si ça en est pour certain c'est de ne plus pouvoir faire varier la luminosité de l’écran .
                  • bogdan1611
                    • Feb 2015
                    hi there i have the same notebook hp 6730s, i have the same problem no backlight i see the hp logo very very hard , i have 3.3v on pin 5 what should i try ? i want to mention that i have tried with different display and inverter ! waiting asap for an answer ! best regards
                    • extrem69
                      • May 2013
                      • España
                      I have same problem, have 3.3 on dim but always off, tried with 3 inverters and 3 lcds.
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        is that amd/ati platoform?
                        if yes, reflow vga and it works, famous rs880... :/
                        Im Back... sort of...
                        • extrem69
                          • May 2013
                          • España
                          hi, this comes with intel cpu and intel graphics
                          • new
                            • Oct 2014
                            • 157
                            • canada
                            problem is lid sensor switch . find it and remove it from the board the backlight will turn on
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • DanPoka
                              by DanPoka
                              02-15-2025, 05:05 AM
                            • jimbofz
                              lg 32LC46 backlight inverter board fault
                              by jimbofz
                              Hi this oldie had no backlight .after replacing caps on 24v rail ,
                              still no b/l this uses inverter type:1315 B1-16A,
                              im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                              all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                              this allows protect to be temporary overridden.
                              b/l now comes on
                              but the left hand side of pic is gradually darker than the right side
                              i have the cct for the tv
                              but it does not have inverter cct.
                              i opened it up to inspect the ccfl tubes
                              and they dont have any...
                              12-19-2021, 06:58 AM
                            • Fernon@Repair
                              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                              by Fernon@Repair
                              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                              VCCIO voltage ok
                              VCCSA Voltage OK
                              VCCPLL Voltage OK
                              Ram Voltage ok
                              RamVTT OK
                              VPP 2.5 OK
                              But No Core Voltage
                              and i want to this vrm ic datasheet or pinout (ISL69269)
                              anyone have this ic pinout voltages?...
                              06-25-2025, 07:19 AM
                            • cheebster
                              iPad Pro 12.9 5th Gen Backlight Issue
                              by cheebster
                              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                              Anyone...
                              05-20-2025, 09:17 AM
