Toshiba Satellite L300 overheating ,bad heatsink?
  • lord
    • May 2011
    • 319
    • Croatia
    Re: Toshiba Satellite L300 overheating ,bad heatsink?
    The method above with freezing the heat pipe is good, but it takes some time. It is much easier to try with fingers if the heatpipe is not equally hot above the CPU and at the ribs where the fan blows but you must turn the fan OFF to check this.
    • fabiog
      • Jul 2011
      • 102
      Originally posted by rievax_60
      Have you tested the heat pipe also to see how well it conducts heat?
      I tested the heatpipe where the cpu and vga is by running hot water and then quickly with cold water they change temperature almost instantly.
      But the fins by the fan always stays warm never too hot nor cold.when I did the test.
      • fabiog
        • Jul 2011
        • 102
        I will try this method by removing the fan and switching on the laptop for a few seconds and see where all the heat spreads.
        • rievax_60
          • May 2012
          • 897
          • australia
          I don't understand how you are testing it.
          Like explained earlier, hold the CPU/GPU plate while running hot water through the fins, the fins that the fan normally blows air through.
          • fabiog
            • Jul 2011
            • 102
            I'm sorry I did it the opposite way I poured the water ontop of the CPU and VGA plates and held the fins in my hand.
            I will have to redo the test.
            • lord
              • May 2011
              • 319
              • Croatia
              #26
              It does matter in which position you hold the heatpipe because it reacts on the matter of gravity (hotter gas is lighter and it moves towards the fins.
              • fabiog
                • Jul 2011
                • 102
                #27
                I tried without the fan connected, the CPU and VGA section gets hot but the fins by the fan stays cool even without fan .I then switched off the laptop, removed heatsink and quickly poured cold water over fins but the CPU and VGA plates stayed hot.
                It took long to cool down and I suspect it's not doing it's job correctly because I assume that when it works properly the fan starts to blow on the fins then the VGA and CPU plates should cool down instantly.
                The sticker on the heatsink says that it's four years old.
                The problem seems to be by the heatpipe inside the fins.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  #28
                  It's not uncommon for heatpipes to leak. Now that you found it, a new heatpipe assembly should solve the problem.
                  A working TV? How boring!
                  • fabiog
                    • Jul 2011
                    • 102
                    #29
                    I have to buy a new one as I don't trust used ones ,they might end up having same problem sooner or later.
                    • joric
                      • Sep 2012
                      • 12
                      • Czech Republic
                      #30
                      I have the same problem with overheating, nothing helps (tried a few thermal pads and compounds). Had to buy a new heatsink and a new cpu (core 2 duo) on ebay, will report later. Does anyone know what are those (1) and (2)? I don't have those on my L300-11q. (1) looks like USB bluetooth (I don't have bluetooth), (2) looks like some kind of a light sensor (I don't have it either).
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #31
                        You see that big chip underneath your CPU, it says NEC/Tokin 0E97/0E128 on it, that is what's causing your problems, not the heatsink or CPU. Look at the Nec/Tokin thread on this forum to see how to fix it.
                        • fabiog
                          • Jul 2011
                          • 102
                          #32
                          (1) I think is the webcam cable since my board is the same.
                          (2) Is speakers.
                          Or the other way round i have to check.
                          I will also report if my problem has been solved as soon as I get heatsink, the new ones are expensive so will ask sellers that sell used if they can test them with the water method.
                          • joric
                            • Sep 2012
                            • 12
                            • Czech Republic
                            #33
                            (2) Is speakers.
                            Thank you! I'm sure that (1) is USB now, pinout looked just like the usb connector on the right side, so yes, it's most probably an USB webcam. I have working speakers but (2) is not occupied so it could be something else.
                            Regarding overheating - it would probably take a few weeks until I get my order (core 2 duo and a heatsink assembly). People say some faulty CPUs are hotter than usual. And I tried testing with a hot water, looks like those pipes don't transfer heat very well.
                            Regarding Nec/Tokin - there's a huge 11-page topic about it https://www.badcaps.net/forum/showthread.php?t=8991 - but it's mostly about power failure, not overheating. I'll try it last, not sure I can remove it well without a fan (most probably will use 4x330 uF for the replacement).
                            • fabiog
                              • Jul 2011
                              • 102
                              #34
                              I've checked and (2) is microphone cable coming from the monitor.
                              Did you order new heatsink or used one ,ebay.com or uk.
                              • joric
                                • Sep 2012
                                • 12
                                • Czech Republic
                                #35
                                I was ordering on ebay.com (paid about $14). They all seem used.
                                If heatsink won't help I'll try shunting Nec/Tokin with a few ceramic capacitors (I really afraid to damage motherboard removing it).
                                Just noticed there are a few new ones, damn! But they will cost at least $54, including shipping.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #36
                                  This capacitor has a very low life and loses capacitance in a relatively short time. The problem is not that it's overheating, the problem is that the metal inside is already fatigued from inadequately spec'd material (Perhaps from an inadequate design) and when the capacitance drops, the VRM will overheat and probably cause instability.
                                  • fabiog
                                    • Jul 2011
                                    • 102
                                    #37
                                    QUOTE=joric;270607]I have the same problem with overheating, nothing helps (tried a few thermal pads and compounds). Had to buy a new heatsink and a new cpu (core 2 duo) on ebay, will report later. Does anyone know what are those (1) and (2)? I don't have those on my L300-11q. (1) looks like USB bluetooth (I don't have bluetooth), (2) looks like some kind of a light sensor (I don't have it either).
                                    [/QUOTE]
                                    Have you checked your temps using a program like hwinfo, mine would go over95º and shutdown.
                                    • joric
                                      • Sep 2012
                                      • 12
                                      • Czech Republic
                                      #38
                                      Sorry for the missing picture, it's here.
                                      Regarding overheating - I guess CPU shuts down at 100C, I've seen something like 95C in hwinfo.
                                      • joric
                                        • Sep 2012
                                        • 12
                                        • Czech Republic
                                        #39
                                        BTW don't even try mounting heatsink without a thermal pad, there's about 0.4 mm gap between the heatsink and the GPU. Now it's working with 0.3 mm pad with grease (ideally, I think, it should be a new 0.5 mm sticky thermal pad) at 90C average (up to 95C), which is not normal (it should be about 45C idle and 60C loaded, according to specs). It's either bad pipes (it's all about 4 years old) or the faulty CPU or the capacitor (or all that at once).
                                        • fabiog
                                          • Jul 2011
                                          • 102
                                          #40
                                          Try the water test like I did and you will see that it's heat pipe related.
                                          I'm just waiting to get a new one.
                                            Toshiba Satellite Pro L300-156 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro L300-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L300-156 boardview and L300-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
