Advice on reflowing HP DV6000?
  • JGAN
    • Aug 2012
    • 28
    I have a HP DV810US (subset of DV6700, subset of DV6000) laptop that has a "no power" symptom most likely caused by a bad NVIDIA chip. I'm looking to reflow the chipset with either a butane pencil torch/heat gun or oven. Is one method "safer" than the other? I would prefer the torch method if there is no reason not to.
    Also, how should I go about doing this? There are so many different methods online, each more absurd than before :/ Basically, if I use a butane torch, I'm going to also have an IR thermometer to monitor the temps and make sure it doesn't get over 250ºC. My idea is just to heat it up slowly from above, about 10ºC-20ºC/minute. I will also have added petroleum-based rosin flux beforehand.
    However, some people say that you should set the motherboard at a 45º angle. In addition, they instruct you to heat it up from the bottom first, and then flip it over to the top and finish reflowing there. Others even go as far as saying that you should apply some pressure to the chip when you are reflowing it.
    Who is correct here? What advice should I take in order to get the best possible results?
    Thanks,
    JGAN
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Advice on reflowing HP DV6000?
    Add flux around the sides of the chip then heat the board lightly from the bottom first, right under the chip, till the top of the chip reaches 140C. This will make the flux go under the chip and clean the solder to some degree (thanks momaka, i previously struggled with pushing the flux in from the top with a thin nozzle on my hot air gun). Then flip it over and heat it from the top.
    I wouldn't go over 230C. Once you've reached 230C, keep it like that for a minute or so, then slowly back away and let it cool down to lower than 50C before you start re-assembly.
    A working TV? How boring!
    • Joun
      • Jul 2011
      • 191
      • Greece
      You're having "no power" or "no video" symptoms?If you have "no power" I don't think it will work,it could be many other things.
      P.S Whatever you do don't EVER apply preasure on chip while reflowing it.This will squash the solder balls underneath(they're more or less liquid remember?) making not contact at all.
      • JGAN
        • Aug 2012
        • 28
        Thanks for the answers everyone,
        I have a "no power" symptom (see here). I checked the coils/inductors, most of the main mosfets, and some caps already. Also, I get 3.35v at the switch, so now I suspect it is the chipset, but I suppose I could be wrong.
        • JGAN
          • Aug 2012
          • 28
          Are you sure its not dangerous to move the board when it's hot?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Obviously, let the board cool back down before you flip it.
            • JGAN
              • Aug 2012
              • 28
              I meant when it's being warmed up from the back?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Yes. Put flux around the GPU, warm the back of the board under the GPU to allow flux to get in, let it cool, then flip it on the other side and heat the GPU from the top.
                • JGAN
                  • Aug 2012
                  • 28
                  Got it, thanks! Any other tips?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    If it has that stupid thermal pad thing on the GPU, replace it with a copper shim with good quality thermal paste on both sides. You can find packs of copper shims on ebay for next to nothing, made specifically for this purpose. But get it up and running first, and then we'll see.
                    • JGAN
                      • Aug 2012
                      • 28
                      Just a quick question: Do you know how to test the NVIDIA chipset with a multimeter? I want to make sure that is really the problem. Schematic is attached if you would like to see it.
                      • 999999999
                        • Sep 2006
                        • 774
                        You can't (reasonably, unless you get extremely lucky) test a chipset with a multimeter.
                        Keep something in mind. The problem with this series is not just the solder pads under the chipset, it's also the solder balls INSIDE the chip itself. Typically the people lucky enough to get one working again, have another failure within a few months.
                        IMO, you're better off parting out the system and buying something else even if that means a used system or a barebone with which you reuse some parts like HDD, memory, CPU - but one with a different chipset.
                        • b700029
                          Banned
                          • Sep 2010
                          • 640
                          A multimeter won't work. You might even damage it with the ohmmeter bias voltage, since these chips are not designed to take much more than ~1v. Either way it'll show as shorted across the power rails, just like a CPU, because it's a high current low voltage device.
                            master hoarder
                            • May 2008
                            • 12175
                            +1
                            I've done that as an experiment on a few Xbox 360s. It's very easy to move the chip sideways and bridge the balls underneath so don't do it. You can also squish them too hard and cause them to bridge.
                            However, you CAN very very gently nudge the chip sideways with tweezers to check if the solder underneath it has melted. If it has, it would be very easy to nudge the chip without having to apply any pressure at all, and the chip should move right back into its place where it was.
                            Keep in mind that if you're not careful or if you have shaky hands, you could potentially nudge the chip too far and bridge some of the solder balls underneath it. For this reason, I HIGHLY recommend people new to reflowing to NOT try it.
                            Glad I could be of any help.
                            • JGAN
                              • Aug 2012
                              • 28
                              Ok, I think I should be able to tell when the solder has melted with the theremometer.
                              What sort of motion should I move in?
                              Thanks everyone for the help so far! I really appreciate it
                              • smason
                                • 1652
                                The last 2 DV6000s I worked on, I moved in the direction of the recyclers.
                                One of the worst POSes HP ever made.
                                • chazzo
                                  CH341 programmer advice, including jumpers seemingly reversed
                                  by chazzo
                                  I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                                  [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                                  I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                                  Yesterday, 08:15 AM
                                • Jidis
                                  Need T-Con Advice (Vizio P602ui-B3)
                                  by Jidis
                                  I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                  He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                  09-22-2025, 05:10 PM
                                • zlr8r
                                  Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                  by zlr8r
                                  Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                  i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                  09-16-2025, 09:54 AM
                                • Borse2008
                                  by Borse2008
                                  • There’s
                                  07-15-2025, 04:55 AM
                                • Green Probe
                                  Mosfet Advice
                                  by Green Probe
                                  Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                                  05-22-2025, 10:49 AM
