Loose Ram Slot
  • Amraks
    • Nov 2011
    • 725
    Loose Ram Slot
    Is there anywhere that will sell the actual ram slots?
    I have this motherboard with a slot that is loose and its causes start up issues. once I take it away the problem don't occur, so its not the ram because I tested it for awhile in other slot.
    Now someone must know where I can get these so I can fix it and its a good board I wanna save it for a media center.
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Loose Ram Slot
    jack one from another board if ya got one! what ram is in machine! differ slots!
    http://www.ebay.ca/itm/DIMS-168-CES-...item19b714b395
    • b700029
      Banned
      • Sep 2010
      • 640
      Re: Loose Ram Slot
      "loose"? What do you mean exactly?
      If it's the soldering that's loose, a little bit of hot air reflow will fix that. If it's something to do with the plastic, epoxy might fix it.
      If all else fails, and you don't want to buy 320 of them from the link above, look for "DIMM SOCKET" on ebay/digikey/mouser/etc.
      • 999999999
        • Sep 2006
        • 774
        Re: Loose Ram Slot
        same question as b700029, is there evidence it is mechanically loose or is it just a conclusion based on the slot causing problems with memory in it while the memory tests ok elsewhere?
        Assuming this is a laptop, one common fault I see every now and then is water/liquid damage. Someone spills liquid on the keyboard and it finds its way to a memory slot directly below and either the liquid or flux residue remaining on the parts causes corrosion which can sometimes be cleaned off, though more often than not when this is the problem the memory itself is damaged too.
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Re: Loose Ram Slot
          I have a board here with the same problem. My brother busted the slot trying to seat the ram. I have another that was killed by mouse piss.
          Mark Twain
          John Paul Jones
          Rod Serling
          • Amraks
            • Nov 2011
            • 725
            Re: Loose Ram Slot
            Its not doing what it was doing now.
            But thank you for your replys and maybe this thread will help someone who is looking to fix the sockets.
            I had no clue, I was searching on ebay for ram slots, so they are called sockets.
            its a pc not a laptop.
            • 999999999
              • Sep 2006
              • 774
              Re: Loose Ram Slot
              ^ Being a PC, the topic might be in the wrong subforum.
              If all else fails, get a dead board from somewhere (yours, a friend's, ebay, local PC shop throwing it away, etc), put a couple of pieces of masking tape on the sides of the slot to form a handle to pull with, flip the board over and move a torch back and forth to melt all the solder to release the slot.
              Some practice with torch flame size, distance, and time heating helps. Try not to catch the PCB on fire, that kind of stinks (I'd do the work outside at the very least). The more tedious part is getting the memory slot off the otherwise working board and clearing solder out of all the holes to get the replacement slot in.
              I'd start to wonder if you really need the slot working for a media center, generally that sort of use doesn't need a lot of memory nor high enough memory bandwidth that it wouldn't work if loss of a slot meant running in single channel vs dual channel memory mode. An exception might be if it is an older lower bandwidth memory type like DDR(1) or older and has integrated video using a portion of the available bandwidth.
              • totoagung2
                by totoagung2
                Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                01-01-2024, 02:43 PM
              • Lifeisfun
                Trying to troubleshoot DDR4 SODIMM slot with slot tester
                by Lifeisfun
                Hi folks!
                I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                Eventually I discovered that it was related to moving the laptop.
                Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                I removed the board got one of those memory slot testers...
                06-04-2025, 02:26 PM
              • szepesif
                Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
                by szepesif
                Hey guys!
                I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
                I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
                04-19-2025, 10:18 PM
              • Byte_76
                Faulty memory slot on Tekram Slot 1 motherboard
                by Byte_76
                I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
                When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
                Also, the floppy drive does not work regardless of bios settings.
                Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
                I have examined the board under my digital microscope and did not find any broken traces....
                04-12-2025, 06:58 AM
              • stormanimal83
                Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                by stormanimal83
                Hey....
                Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can“t understand...
                01-18-2024, 02:15 PM
