hp g56 no backlight
  • woodford
    • Jun 2011
    • 27
    hp g56 no backlight
    i have seen a few g56 laptops with the problem of no backlight.they all have led screens so no inverter to diagnose and i cant seem to find any fuses on the mainboard, any idea's where to start diagnosing this fault, ive tried new cable and new screen so definately mainboard issue and ive seen enough of this problem to think it may be a common fault.
    thanks
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: hp g56 no backlight
    there you go, the problem is most likely in the lcd..
    • Mario
      • Sep 2007
      • 64
      Theres two types of LED lcd's, both40 pin connector, if it has a smaller one, the backlight driver is on the mainboard. Maybe check there if the output has any voltage. It should be 30 or 27 v. The longer connections have the backlight controller on the LCD. Check if theres 12v going in to the LCD connector. And check the BL_EN there should be 5v or 3.3 v. Maybe you can force it on with like a 3v or 5v power source.
      • b700029
        Banned
        • Sep 2010
        • 640
        If you are certain what the connections are, and the current requirements, you can try powering up the LEDs directly.
        • unlockdev
          • 81
          common problem
          Filed +3.3 to plug a 36 foot light running at maximum and not adjustable.
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
          • alro7779
            Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
            by alro7779
            Hello, guys!
            I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
            Alex....
            10-03-2025, 05:49 PM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • Boyxba
            TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
            by Boyxba
            I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
            05-13-2023, 11:47 AM
