Dell Inspiron 1545 Dim LED
  • incradibles
    • Feb 2011
    • 43
    Hi
    I have a problem with dell inspiron 1545 when i turn it on a dim display comes on the led screen while a normal on external display i have changed the led's but no backlight comes on always dim so may be its gpu issue or cable.
    Silence Like Dreams
  • tschanuka
    • May 2011
    • 21
    Re: Dell Inspiron 1545 Dim LED
    Hi.
    Yes defective GPU and cable can cause such problems, but also other parts of the motherboard for power and backlight controls the display.
    I uploaded LVDS part of the schematic for you to check:
    http://ultrashare.net/hosting/fl/a9bbf0ba2a/lvds
    I'm from Germany
    Please excuse if my English is not so good or misleading. Trying my best.
      master hoarder
      • May 2008
      • 12170
      If an external monitor looks normal, then it's unlikely that the GPU is defective.
      Have a look at the backlight controller instead or the circuit that controls the backlight brightness.
      • jsog
        • Feb 2011
        • 220
        Blown fuse? http://forum.notebookreview.com/dell...cklight-5.html
        Post #48 shows a picture, don't know if it's the Inspiron 1545 but should at least be similar.
        Don't do what they do there! Bridging a fuse is asking for trouble. But it might help you locate and test the fuse, then people here can help locate a replacement.
        • tschanuka
          • May 2011
          • 21
          @momaka:
          Hi, I agree with you.
          But display backlight is controlled/enabled by the North/GPU in this model.
          That part or connection of the chip can also fail as the other functions like graphic processing.
          Yes, it is not much likely if there are no other signs of GPU or Northbridge failures. It could just not be excluded, that´s why I mentioned it.
          I think the hint from jsog is a good point to start.
          LED Backlight issues seem to be a common problem with the 1545.
          I'm from Germany
          • Linkk
            • Aug 2011
            • 9
            Does anyone know what the capacitor next to the fuse is (C69) ?, as i've managed to knock it off and damage it whilst taking off the fuse, I've taken a picture of mine, its the same board.
            • marcellodj
              • Nov 2010
              • 99
              I had same problem with a packard bell: video ok on svga out, no blue screen or other problems, but no video on panel with ccfl on, tried to change panel, same result.
              Reflowed gpu and now is perfectly working.
              Best regards
                master hoarder
                • May 2008
                • 12170
                If the capacitor doesn't appear to be physically broken, check it for short circuit with a multimeter. If it doesn't appear short-circuited, just solder it back into place again. Otherwise if it is broken or shorted, just find a cap of the same size from other scrap motherboards.
                It looks like C69 is a decoupling cap, along with C68, so the board will probably work without it fine. It's still a good idea to place a cap of some sort in that spot, though.
                • tschanuka
                  • May 2011
                  • 21
                  C69 is 1uf 50v.
                  I'm from Germany
                  • incradibles
                    • Feb 2011
                    • 43
                    Thanks guys i got fuse defaulter, i changed with new one i giot back my screen back light. you guys are rocking thanks again
                    Silence Like Dreams
                    • spidey
                      climbs
                      • Dec 2012
                      • 644
                      • Cyprus
                      i need the schematic of this board!!! searching but havent found yet. if someone shares, would be great.
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        i'm changing lcd screen with led one, i'm using the 3m converter cable lcd to led display. I want to find the vin, brightness, gnd and on/off control. it was easy to find vin and gnd. But now i have 6 more cables to connect but only 2 of them. i have one +3v(i guess on/off this one) and the rest are no voltage. does anyone know the brightness signal, so i can measure it with the scope. Fuse was blown, i bridged it. 10.8 vin i have.
                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 03:36 PM
                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 03:30 PM
                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 03:28 PM
                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
