Problem video A1502
  • zimeyh
    • Apr 2014
    • 18
    • alibahbay
    Problem video A1502
    Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Problem video A1502
    when video is off, if u press trackpad or similar u get video back ??
    when u have no video, fan still spinning ?
    could be lid sensor problem.
    • zimeyh
      • Apr 2014
      • 18
      • alibahbay
      hello! It turns on normally, but when the user/password window exits there is no longer any video on the macbook screen, there is sound, I have a backlight because it turns on and you can see the apple. So when I connect the external monitor I have video on both screens and when I disconnect it it disappears
      • zimeyh
        • Apr 2014
        • 18
        • alibahbay
        Up
        • mon2
          • Dec 2019
          • 14332
          Check open lid sensor voltage to ground.
          Test in safe mode boot.
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • hugocarmo
            Grundig GV-250 Repair problem. (Video inside post)
            by hugocarmo
            Hi everyone.
            I have the following problem.
            I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
            In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
            01-19-2023, 06:46 AM
          • Askic
            Problem with monitor DS-D5022QE-B
            by Askic
            Hello to all,
            I have a problem with monitor that is delivered together with CCTV system.
            The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
            I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
            05-31-2023, 03:14 AM
            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
            09-12-2024, 02:00 PM
          • CptChronic
            Samsung LU32J590UQUXEN Monitor display problem
            by CptChronic
            I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
            Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
            But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
            04-24-2023, 04:33 PM
