Dell E7480 needs help
  • mrmouse17
    • Oct 2021
    • 33
    • viet nam
    the condition of the machine running or dumping. I replaced the ram and checked the ram power supply and everything is fine. Can someone give me an opinion?
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Sathsul
    Dell Latitude 5431 issues with dumping bios
    by Sathsul
    So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
    The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
    However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
    10-28-2025, 07:49 AM
    DELL Latitude 7480 E7480 Laptop Boardview
    LA-E132P CAZ20...
    10-26-2024, 03:29 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
