TT 94V-0 E326167 motherboard not powering up
  • duraven
    • Oct 2023
    • United Kingdom
    Hello! Embedded Software Engineer here, for fun trying to investigate a friend's laptop not powering up problem – first time opening a laptop.
    • The physical power button has been broken on the laptop and the friend advised that they needed to poke the area with a pen to get it to start
    • Eventually the pen poking stopped working and now the laptop does not power on at all.
    I have stripped down the laptop down to the motherboard but I cannot simulate the button press or otherwise see anything happening when the power is applied.
    Motherboard model TT 94V-0 E326167 <see image Motherboard model.jpg>
    As per https://www.badcaps.net/forum/showthread.php?t=116266 I could not find the schematics for the board.
    More pictures of the power area please see: <Power area top view.jpg> and <Power area bottom view.jpg>
    I have blindly guessed that to simulate the power button press I need short to short the contacts here – perhaps that is wrong? Please see <Button press.jpg>
    I have also noticed a bit of damage around the power circuitry and the (charge applied?) LED missing, perhaps the damage is causing the problem, please see
    <damaged area zoomed in.jpg>
    I would really appreciate any comments thank you in advance.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: TT 94V-0 E326167 motherboard not powering up
    https://www.badcaps.net/forum/showthread.php?t=88758
    HannStar don't design boards, they manufacture the PCB. "J MV-4" and "94-V0" are not board model numbers, they are generic markings about PCB characteristics.
    • lotas
      • Jan 2016
      • 4755
      • Russia
      Motherboard model - 71R-NH4CU6-T810
        • 21641
        Schematic https://www.badcaps.net/forum/showthread.php?t=125246
        • Nagy Daniel
          ASUS TUF Gaming A17 FA707RM-HX038W / Motherboard DANJMMB1AA0 Rev: A // not powering on
          by Nagy Daniel
          I'm new in the world of repair, and I have a laptop that does not turn on.
          I don't know exactly the past of this laptop, I got it in a non-functional state.
          The LDO3 and LDO5 are present, and it provides 3.3 and 5V.
          When I started to diagnose the motherboard, the regulator for the LDO3V and LDO5V was quite hot, I checked it with a thermal camera, and the 3V from the DNBSWON was missing, so I replaced the IC Chip from a donor board (the ic chip is from the same type of motherboard)
          Now, the regulator is fine, it's not heating,...
          03-05-2025, 02:57 AM
        • glovecaps
          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
          by glovecaps
          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Dergal T Stonkerson
          LCD monitor motherboard not powering up
          by Dergal T Stonkerson
          I have a faulty motherboard controlling G150XG01 LCD monitor. Pictures attached of two separate motherboards. I have being searching online for a schematic of the boards, none of the codes on the boards are giving any results when searching. Is it possible to get schematics for these? Is it possible to repair these surface mount pcb's, what are the common faults?
          Thanks in advance for any help/advise....
          08-15-2024, 04:00 AM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
