Lenovo V130-15IKB: no display
  • DrFalken
    • May 2008
    • 122
    Hello everybody !
    I'm working on a Lenovo V130-15IKB M/B LV315KB MB 17807-3M 448.0DC04.003M.
    When the client brought it, laptop was almost dead: turn on but no image, no backlight, just a solid CAPS LOCK and POWER led.
    Dumped original BIOS.
    Flashed some BIOSes found here, also with ME cleared, and now it's booting: still no image on laptop's screen but it's working on HDMI.
    Actually I've found some issues also on HDMI: sometimes I get no signal but it's booting because can connect to the desktop with a remote control software.
    Readings (turned ON, only PSU, no battery):
    - DCBATOUT_LCD = 9.46V
    - LCDVDD = 3.8V
    - LCD_BRIGHTNESS = 0
    - BLON_OUT_C = 0
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • andreslimbo
    Lenovo HS45Q - HS45S (NM-D891) black screen while booting
    by andreslimbo
    I have a question about a Lenovo board (HS45Q - HS45S (NM-D891) - later I will update this with the exact Lenovo model number.
    I'm not experienced at all, but I managed to get this laptop from someone that needed to get rid of it. He had a water bottle in his bag which started leaking.
    The initial problem was that it didn't show anything on the display, but it did show stuff when I connected an external display.
    I saw water damage around the lcd connector. After cleaning and checking all wires and lines, somehow during testing I managed to blow up IT8227....
    03-16-2025, 02:41 PM
  • Ven
    Lenovo V330-15IKB - Not booting, No Display
    by Ven
    Lenovo V330 - 15IKB - Intel i5 8th Gen CPU
    My Lenovo laptop does not turn on, no display .
    As soon as the DC jack (Lenovo Charger) is plugged in, the power LED and Caps Lock LED turn on, but there is no display.
    The fan spins for a short time after plugging in the DC jack and stops, then in about 20-30 seconds it starts to spin slowly and gradually increases to maximum speed. The CPU is slightly warm.
    The main power rail measures 8.7V. The battery voltage is 7.6V, and the battery sticker states "Charge with 8.7V." Both 5V and 3.3V rails
    03-21-2025, 11:29 AM
  • Zarithya
    Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
    by Zarithya
    I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
    11-02-2025, 06:26 AM
    Lenovo 3000 Series Schematic
    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
    3000 C100 laptop with Braille keyboard
    Lenovo 3000 C
    C100, C200 - 15-inch XGA screen
    Lenovo 3000 N
    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
    N500 - 15.4 inch screen.
    Lenovo 3000 V
    V100, V200 - 12.1-inch WXGA models
    Lenovo 3000 G
    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
    10-04-2024, 06:05 AM
