A2338 820-02020 Backlight is on, no image after liquid spill
  • trepachka
    • Oct 2022
    • 440
    Laptop boots but there is no video, backlight is on after the liquid spill. I can hook up the laptop to a TV and the image is fine there.
    Can anyone point me in the right direction? Could it be a dead screen? Most of the liquid spill is concentrated around system fan connector.
  • mon2
    • 14631
    Re: A2338 820-02020 Backlight is on, no image after liquid spill
    I do not have access to the schematics right now as I am overseas but check for the presence of a mux (multiplexer) which will steer the video to internal or external sinks. Also confirm the lid sensor operation which may be directing the video. Check the mux direction pin voltage to ground as well as the enable pin.
    • trepachka
      • Oct 2022
      • 440
      PP3V3_SW_LCD=3.3V
      PP5V_SW_LCD=5V
      LID OPEN is @ 1.8V
      Is there a fuse I can check, perhaps? I do get backlight, no video.
      • trepachka
        • Oct 2022
        • 440
        Ppvout_lcdbklt=44.4v
        • reformatt
          • Feb 2020
          • 1465
          If the backlight is enabled, this at least means there is communication with the display. Likely a bad screen.
          • trepachka
            • Oct 2022
            • 440
            Will order a screen, let's see what happens.
            • slimmy182
              A2338 new M1 MacBook Pro problem Logic Board related after liquid spill 820-02020
              by slimmy182
              Hello, I've got this Mac from a friend who spilled wine on it. MacBook boot right onto options screen and does not boot the os. Reinstalling Mac Os does not help, it does conclude but same option screen after install. If I try to select the startup disk it gives me "error SDErrorDomain 108" and it does not go forward. I cannot manage to enter DFU for whatever reason. I opened and found corrosion nearby trackpad socket and other components who I cannot identify as I don't have schematics, you can see the photos above. After try to clean with IPA I noticed that i've lost a pin on the trackpad...
              04-27-2022, 03:18 PM
            • bigbadbios
              a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
              by bigbadbios
              I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
              When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
              I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
              Your help is GREATLY appreciated. Thanks!
              08-18-2024, 05:47 PM
            • larrysito111
              dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
              by larrysito111
              got here a liquid damaged alienware
              the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
              so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
              so with the usb-c external monitor is getting to bios and OS
              otherwise not
              so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
              but still not the internal monitor
              (tested 3V and 5V going to the...
              06-12-2025, 04:16 PM
            • mferna14
              Lenovo Thinkpad T490 liquid spill-boardview request
              by mferna14
              Hi All, I am working on a Lenovo Thinkpad T490 liquid spill. The spill/corrosion broken some tracks & cannot figure out without the Boardview. Can anyone share the boardview for this Lenovo ThinkPad T490 NM-B901 Rev: 1 . I think ThinkPad T590 are the same. Thanks in advance
              07-31-2023, 03:14 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
