Apple macbook - How to remove Dynatrace software?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Hello.
    Have apple macbook pro that have some controlling software on it Dynatrace. Reinstall not help as this software self install again. So how to remove this software?
  • kevingill
    • Jun 2013
    • 152
    • England
    Re: Apple macbook - How to remove Dynatrace software?
    Which model are we talking about here?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3609
      • slovakia
      Originally posted by kevingill
      which model are we talking about here?
      a2141 emc3347
      • kevingill
        • Jun 2013
        • 152
        • England
        Have you tried wiping the drive and re-installing from a USB stick?
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          This is an MDM lock which will require changing of the serial or contacting the company to remove the lock.
          sigpic
          MEOWING IN THE IMPOSSIBLE UNIVERSE!
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3609
            • slovakia
            changind serial can be, but what to tell that company?
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 667
              Changing serial changes a serial. MDM gets removed once you do that.
              sigpic
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3609
                • slovakia
                can be serial changed by bios editing? did changing serial make any other problems?
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 667
                  No. There is no bios editing on T2 Macs...
                  you must desolder the ROM Chip off the board and then program it with a different serial with a programer tool while the chip is connected to the tool. This requires soldering skills and there is no other way of changing serials on T2 machines except this way for now.
                  sigpic
                  • envym
                    MacBook Pro 2018 with Activation Lock
                    by envym
                    Hi everyone!
                    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                    06-27-2025, 08:54 AM
                  • samstown
                    Apple 076-00236 Genuine Apple Data Migration Tool for MacBook Pro 2016 2017
                    by samstown
                    This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
                    Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
                    Claude...
                    05-09-2024, 02:02 AM
                  • arahban
                    Apple MacBook A2442 faulty PMIC - Question about possible replacement
                    by arahban
                    Hello Gentlemen,
                    I am working on an apple MacBook A2442 board pn 820-02098-A with a visible short on the PMIC U7700 MVK-PLUS as per the schematics
                    I have a donner board from apple macbook pro m1 A2338 PN 820-02020 and I saw that the PMIC U8100 TMLT46B0-JPE could be a possible replacement for the U7700
                    Can you please help me confirm if the U7700 can be replaced with U8100 ?
                    APL1098 is it the same as APL1096
                    Thank you very much in advanced
                    Ahmad
                    12-23-2023, 05:25 AM
                  • a_p3rson
                    Apple Watch Charging Controller Schematics / Boardview - 820-02601
                    by a_p3rson
                    Hi there,
                    I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                    You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                    This daughterboard uses an interesting...
                    04-21-2025, 11:41 PM
                  • mferna14
                    Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                    by mferna14
                    Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                    06-25-2025, 11:26 AM
