Mac EFI Toolkit
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Hey Muerto, question. Is this program capable of reading information SUCH as serial off a MacBook with T2 chip without the need to desolder the SOCROM chip and reading it? Is there a way to read via DFU? Just curious , or do you have a method or if not is there method in development?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • MuertoGB
      • Sep 2021
      • 94
      • United Kingdom
      #62
      Originally posted by Stephen
      In order to bypass an MDM it would be ran with software, however when trying to REMOVE the MDM lock permanently, one would need to change the serial to the device. If you can change the serial number on the device without the need to desolder the chip that retains the information of the board such as EFI lock/FIRMWARE LOCK, Serial number of the board then that would be pretty awesome. But in order to remove the MDM lock on T2 machines one has to desolder the SOCROM chip next to the T2 chip. Reprogram with ASPROGRAMMER, and then change the serial with WinHex. Find the serial, DO NOT change any of the code but the serial so it can still normally boot. That is how its done.
      Good to know, I've added this functionality to version 2. It is able to change the serial in the SPIROM dump.
      • MuertoGB
        • Sep 2021
        • 94
        • United Kingdom
        #63
        No it cannot, it requires a SOCROM dump. Only the T2 has access to the SOCROM, it must come off to be reprogrammed.
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          I see so I am essentially doing the same thing still. This program is good, working progress. Might be a good idea to find a way to get the program to read serials on M1 devices and see if we can find a way to change serial on M series laptops, a good start would be an M1 for now and see if we can get dumps on that and be able to read the serial. If we can manage to do that, MDM removal would be viable for off set devices that companies get rid of and forget to remove their MDM. Very common in this industry at scale.
          sigpic
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            #65
            Wow! THANK YOU! A big human thank you for your work! I am shocked by this simply incredible tool! Now I can quickly see why I have a bunch of files on my computer and also see why the chips are lying on my desk! Thank you!
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              #66
              to unlock EFIROM i use this device ! can i use it to read SOCROM T2?
              • MuertoGB
                • Sep 2021
                • 94
                • United Kingdom
                #67
                The SOCROM is a rather simple structure. We have the header, followed by two endoded sections (possibly DER ASN.1 objects?), then the System Config store (SCfg) and then NVRAM (May be some other small blips of data around the place).
                On Apple Silicone devices, the Scfg in the SOCROM has been either completely removed, or moved into an encoded section. There's not much I can do here at the moment, unfortunately. However, I continue to pull apart and find what I can.
                • MuertoGB
                  • Sep 2021
                  • 94
                  • United Kingdom
                  #68
                  Thank you, I appreciate the kind words.
                  For SOCROM dumps from the SPIROM, the IC is 1.8v 8-USON (or USON8) 4x3mm.
                  1. Does EZP support 1.8v? If not you need a 1.8v adapter.
                  2. USON8 4x3 adapter here on AliExpress: https://www.aliexpress.com/item/1005007137888078.html (Choose Color: USON8-4X3-XG)
                  More information I wrote here:
                  https://logi.wiki/index.php/T2_Diagn...OM_Programming
                  • MuertoGB
                    • Sep 2021
                    • 94
                    • United Kingdom
                    #69
                    Version 2.0.0 released:
                    https://github.com/MuertoGB/MacEfiTo...leases/tag/200
                    Any issues, please get in touch.
                    • PITERPENY
                      • Jul 2023
                      • 455
                      • Ukraine
                      #70
                      I bought the adapter you recommended, but I have a problem and I hope you can help me solve it.
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        #71
                        but I forgot about the 1.8v adapter.
                        • MuertoGB
                          • Sep 2021
                          • 94
                          • United Kingdom
                          #72
                          Purchase a 1.8v adapter and we'll go from there, do not plug the T2 SOCROM into 3v3, there is an extremely high chance it will burn out.
                          • Kien Pham
                            • Nov 2024
                            • 3
                            • japan
                            #73
                            [QUOTE=MuertoGB;n3505145]
                            please guide me to unlock icloud from t2 rom chip. i am stuck at this step. model mac mini 2018 A1993 I have the bin file of the chip
                            I would be grateful for your help
                            • MuertoGB
                              • Sep 2021
                              • 94
                              • United Kingdom
                              #74
                              [QUOTE=Kien Pham;n3509543]
                              You cannot "unlock iCloud" with this application.
                              • MuertoGB
                                • Sep 2021
                                • 94
                                • United Kingdom
                                #75
                                Version 2.0.1 released:
                                https://github.com/MuertoGB/MacEfiTo...leases/tag/201
                                The manual has been rewritten and added to the project:
                                https://github.com/MuertoGB/MacEfiTo...ication-manual
                                • Kien Pham
                                  • Nov 2024
                                  • 3
                                  • japan
                                  #76
                                  [QUOTE=MuertoGB;n3510142]
                                  how can i unlock icloud? glad you responded
                                  • MuertoGB
                                    • Sep 2021
                                    • 94
                                    • United Kingdom
                                    #77
                                    [QUOTE=Kien Pham;n3510673]
                                    I don't know, make a post in the forum.
                                    • reformatt
                                      • Feb 2020
                                      • 1412
                                      iCloud activation lock is linked to multiple hardware items on T2 and above, and not just linked to serial number. It was changed years ago by Apple due to some practices that China were using to bypass the locks on iPads.
                                      • Kien Pham
                                        • Nov 2024
                                        • 3
                                        • japan
                                        #79
                                        i really hope someone can help me how to unlock my mac mini
                                        • PITERPENY
                                          • Jul 2023
                                          • 455
                                          • Ukraine
                                          #80
                                          HI MuertoGB
                                          ​I finally got the adapters and built the pyramid! But my programmer does not detect the chips automatically and I still get an error! Please help me determine the chip settings!
                                          • TuanTongbadcaps
                                            Change CPU multiplier through BIOS editing
                                            by TuanTongbadcaps
                                            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                            07-22-2024, 07:57 PM
                                          • sezsizada
                                            hp 15-fb0000nx bios editing request
                                            by sezsizada
                                            Hello
                                            I need your advice and help on a topic.
                                            Since we did not have the existing chip on the HP motherboard with a faulty VGA chip, we installed a different chip. How can we enable this on the device?
                                            old vga chip GN20-P1-A1
                                            new vga chip GN20-P0-A1
                                            I add original bios water
                                            thank you in advance...
                                            07-21-2025, 10:24 AM
                                            Copy DMI info easily with Hex editing software and Macro script
                                            by SMDFlea
                                            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                            02-28-2023, 02:14 PM
                                          • Aditya11ttt
                                            On Board Ram Disable via Bios Editing
                                            by Aditya11ttt
                                            Post Hp | Dell | Asus | Lenovo
                                            on board Ram Bios we try to disable via bios edit.
                                            07-31-2022, 08:03 AM
                                          • Rustam14
                                            help with bios editing UX325E
                                            by Rustam14
                                            Zenbook 13 UX325 Intel Core i5-1135G7 UX325/425EA REV 2.1
                                            Hello! I can’t edit the bios on the asus, I tried to manually glue it from ASUS support and through Fit.
                                            turns on without iso tries to initialize and turns off...
                                            04-16-2022, 05:16 AM
