HP Pavillion 15-ec2253ng (DAG3HIMB8C0 REV.C)
  • Oliver111
    • Jul 2018
    • 52
    • Kiev
    Hi! Need help for repair this unit. Problem not typical.
    All voltages are present (CPU, GPU, 5v, 3.3v, charging system).
    When I try to install Windows it's shutdowns automatically (in 10-15 sec after it recognize flash drive)
    3.3V and 5V have a good resistance (kOm's). 5V when work drops to 4.8v, unstable.
    I bought 2 laptops with same issue. I think maybe it a typical problem.
    Motherboard - DAG3HIMB8C0 REV.C, Quanta G3HI.
    Can anybody help? Thanks
  • Oliver111
    • Jul 2018
    • 52
    • Kiev
    Re: HP Pavillion 15-ec2253ng (DAG3HIMB8C0 REV.C)
    Two laptops arrived with broken DC PowerJack.
    With thermalcamera i saw a heating EC controller, switcher? around usb port, and diode near ec controller.
    • natic
      • Sep 2018
      • 34
      • EU
      Hello!
      This chip is a "Power distribution switch" for the USB port. It's very likely damaged. Remove it from the board.
      Measure the resistance to ground on the cathode (-) pin of this diode.
      • Oliver111
        • Jul 2018
        • 52
        • Kiev
        Originally posted by natic
        Hello!
        Thanks for response. I replace usb switch, but no changes.
        All resistance kOms (including resistance on cathode, caps around ec). Its heating resister, not diode. It going to 67 pin ITE8987E (AD_TYPE). 5.5V on 67pin, I think its too high.
        In this circuit 3 resisters - 100 Om, 8kOm, 2kOm. Heating last resister 2kOm.
        Forgot. Voltage in a power button also 5V. It's good? Usually 3.3V.
        Thanks for help, sir
        • natic
          • Sep 2018
          • 34
          • EU
          Does this chip still heats up?
          By the way, you can test the board without this chip. It should work normally, except the USB port.
          - Measure the resistance to ground on pin 67 of KBC chip.
          - Measure the resistance between the central pin of the DC socket and pin 67 of KBC chip.
          - True, this voltage is too high. Measure the voltage to ground on central pin of the DC socket.
          • Oliver111
            • Jul 2018
            • 52
            • Kiev
            After replace usb switch don't heating.
            resistance between the central pin of the DC socket and pin 67 = 2.09kOm
            resistance to ground on pin 67 of KBC chip = 7.91kOm
            • natic
              • Sep 2018
              • 34
              • EU
              Measure the voltages to ground on pins 11, 12, 26, 74, 127 of KBC chip.
              • Oliver111
                • Jul 2018
                • 52
                • Kiev
                Without ITE8987E (firmware saved):
                11 - 0V
                12 - 0V
                26 - 3.3V
                74 - 3.3V
                127 - 3.3V
                Strange voltages on 67 and 71 pins (3.8V - 67 pin; 71 pin - 2.8V).
                For test I use original 65W HP genuine adapter.
                All resisters in this circuit normally (AD_ID).
                • natic
                  • Sep 2018
                  • 34
                  • EU
                  Is there still 5V on pad 67 on the place of KBC chip (with the KBC chip removed from the board)?
                  How about that?
                  • Oliver111
                    • Jul 2018
                    • 52
                    • Kiev
                    How about that?
                    No. Without EC - 3.8V (67 Pin)
                    19.5V on central pin (AD_ID).
                    • natic
                      • Sep 2018
                      • 34
                      • EU
                      Measure the resistances between listed pins of power connector in cases a, b, c.
                      - Between pin 1 and pin 10.
                      - Between pin 1 and pin 11.
                      - Between pin 1 and pin 12.
                      a) DC socket cable disconnected from the motherboard.
                      b) DC socket cable connected to the motherboard, but disconnected from the power supply.
                      c) DC socket cable connected to the motherboard + power supply connected, but the power supply disconnected from the wall 220V mains socket.
                      • baki60
                        • May 2020
                        • 78
                        • Türkiye
                        sorunDid you solve the problem, masters?
                        I have the same problem
                        • oleinikov_s
                          • Feb 2019
                          • 9
                          • ukraine
                          I think the problrm with KBC ITE, i have the same problem, after replacing i will write solution....
                          • oleinikov_s
                            • Feb 2019
                            • 9
                            • ukraine
                            The problem is KBC, replacing KBC and flash it with Vertyanov programmer.
                            • Oliver111
                              • Jul 2018
                              • 52
                              • Kiev
                              Thanks. My master tell me a problem wit cpu power. May be he replace or reflash kbc.
                              • VEGARZ
                                • May 2010
                                • 3
                                Hi, I'm afraid I have the same issue.
                                Is it possible to get the KBC firm to flash it.
                                Thanks.
                                  • 20898
                                  Thanks.
                                  You can request it in the bios requests forum - https://www.badcaps.net/forum/troubl...-requests-only
                                  • VEGARZ
                                    • May 2010
                                    • 3
                                    👍 Sorry.
                                    • hopkok
                                      • Oct 2014
                                      • 178
                                      • Slovakia
                                      Hi guys, anyone can help me with resistor value?
                                      Board: dag3himb8c0
                                      Got this board in this condition, one BIOS chip leg broken. I accidentally lost resistor in red circle. No schematic or BV available...
