denver Taq 10153MK2 firmware Update
  • samtron786
    • Aug 2016
    • 157
    • germany
    Hello I am looking for the firmware update the device starts
    is in bootloop, no buttons work anymore
    until the battery runs out
    • 30979
    Re: denver Taq 10153MK2 firmware Update
    how does that help?
    you need to get it into recovery or fastboot mode.
    that needs the power and volume buttons working
    • samtron786
      • Aug 2016
      • 157
      • germany
      Unfortunately the buttons don't work either
        • 30979
        so if you disconnect the battery, then reconnect - does it turn on without the power button?
        • CapLeaker
          Leaking Member
          • 8118
          That's an android tablet? First I'd try something like a factory default or disconnecting the battery for a bit and then try again.
          • samtron786
            • Aug 2016
            • 157
            • germany
            Yes, I had disconnected the battery and had the same problem
            I haven't tried without the power button yet
            Yes this is an Android tablet that is
              • 20656
              https://denver.eu/consumer-support/upgrades-firmware/
              All upgrades & firmware are placed (if available) under each product.
              Quote:
              Please notice - tablet firmware are never placed on the website - if you need firmware for your tablet (we typically only have the same as there are on already, so only if it gives you problems) please write to us with modelnumber, PO/Serial number, and then we can send the correct firmware to you. Our contact info are: support.hq@denver.eu
              Please use the search field above this message. Here you can write the model number, and it will show you both the product itself, user manuals, high resolution photos + if there are updates available for the model.
              • samtron786
                • Aug 2016
                • 157
                • germany
                Good day
                I have already written an email, I have to wait
                • TheUser
                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                  by TheUser
                  Hello to everyone ,
                  This is my first post here, and i would like to share with you a small story in case you can help me.
                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                  02-10-2024, 02:07 PM
                • rumpumpel1
                  ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                  by rumpumpel1
                  Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                  10-24-2024, 08:59 AM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                • pp74
                  Marantz NR1508 USB firmware update image
                  by pp74
                  Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
                  Regards
                  05-10-2025, 11:55 PM
                • Faluky
                  firmware for Marantz SR5008 stuck in update loop
                  by Faluky
                  After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
                  Best regards.
                  Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
                  01-17-2023, 04:33 AM
