Asus X415JA rev 3.1 no turn on
  • timo667
    • May 2017
    • 10
    • Poland
    I have a problem with Asus X515JA-BQ2634W. The motherboard model is X415JA rev 3.1. The laptop got water-damaged around the EC (IT5125E-128), IO connectors, and the audio area on the opposite side of the PCB. After cleaning up the water damage and reflowing the EC, the laptop started turning on, and everything worked correctly. However, after two days, it suddenly stopped turning on. Now, when connected to the power supply, it draws around 0.01A. On the motherboard, I have measured voltages of 3V and 5V, as well as LDO3 and LDO5, generated by the Richtek RT8249C (2N=). Additionally, I have identified a coil where 1.8V appears when the power supply is connected. All coils show the correct resistance on a multimeter. Due to the water damage around the EC, I removed it to check if there were any traces underneath, but all connections seemed fine. The BIOS has been reprogrammed. Can anyone suggest where to look for the problem?
  • mon2
    • 14634
    Re: Asus X415JA rev 3.1 no turn on
    The board is not consuming any current at a 10mA draw. Check the adapter voltage at the dc connector and continue to trace the same input power rail to the 2*DCin mosfets. Likely these are not turning on.
    Measure the voltage to ground of:
    Source (1-2-3)
    Gate (4)
    Drain (5-6-7-8)
    Pins of each mosfet. Post each measurement.
    • timo667
      • May 2017
      • 10
      • Poland
      On DC Connector have 19V
      on first mosfet (Code SMD: E120AT I think is RQ3E120AT)
      Measured the voltage to ground of:
      Source (1-2-3) 19V
      Gate (4) 12,4V
      Drain (5-6-7-8) 19V
      on second mosfet (Code SMD: E120AT I think is RQ3E120AT)
      Source (1-2-3) 19V
      Gate (4) 12,5V
      Drain (5-6-7-8) 19V
      Intersil 9238CH
      1. 8,4V
      2. 8,4V
      3. 8,4V
      4. 5,08V
      5. 5,08V
      6. 0V
      7. 0V
      8. 5,08V
      9. 0,11V
      10. 8,4V
      11. 8,47V
      12. 13,3V
      13. 8,3V
      14. 19V
      15. 19V
      16. 19V
      17. 18,7V
      18. 5,08V
      19. 0,86V
      20. 0,12V
      21. 3,3V
      22. 3,3V
      23. 0V
      24. 5,08V
      25. 0V
      26. 5,02V
      27. 0V
      28. 1,43V
      29. 0V
      30. 0V
      31. 0V
      32. 8,4V
      1. 0V
      2. 0V
      3. 3,3V
      4. 0,1V
      5. 0V
      6. 3,3V
      7. 0V
      8. 3,3V
      9. 8,2V
      10. 3,56V
      11. 0,28V
      12. 8,4V
      13. 5,13V
      14. 5,14V
      15. 0,05V
      16. 5,21V
      17. 9,75V
      18. 5,14V
      19. 0V
      20. 3,3V
      All measured voltage was after plug the power supply to dc connector.
      • timo667
        • May 2017
        • 10
        • Poland
        Managed to fix the laptop, the issue was the lack of voltage on the 3VSUS_PWRGD line on 67 Pin EC, after fixing this voltage, the laptop started to boot up.
        • maksimthuk
          • Jan 2012
          • 23
          • Україна
          Hello. What did you do to make the tension appear on 67 Pin EC?
          • elrahmat
            • Apr 2019
            • indonesian
            Source (1-2-3) 19V
            Gate (4) 12,4V
            Drain (5-6-7-8) 19V
            Source (1-2-3) 19V
            Gate (4) 12,5V
            Drain (5-6-7-8) 19V
            Intersil 9238CH
            1. 8,4V
            2. 8,4V
            3. 8,4V
            4. 5,08V
            5. 5,08V
            6. 0V
            7. 0V
            8. 5,08V
            9. 0,11V
            10. 8,4V
            11. 8,47V
            12. 13,3V
            13. 8,3V
            14. 19V
            15. 19V
            16. 19V
            17. 18,7V
            18. 5,08V
            19. 0,86V
            20. 0,12V
            21. 3,3V
            22. 3,3V
            23. 0V
            24. 5,08V
            25. 0V
            26. 5,02V
            27. 0V
            28. 1,43V
            29. 0V
            30. 0V
            31. 0V
            32. 8,4V
            1. 0V
            2. 0V
            3. 3,3V
            4. 0,1V
            5. 0V
            6. 3,3V
            7. 0V
            8. 3,3V
            9. 8,2V
            10. 3,56V
            11. 0,28V
            12. 8,4V
            13. 5,13V
            14. 5,14V
            15. 0,05V
            16. 5,21V
            17. 9,75V
            18. 5,14V
            19. 0V
            20. 3,3V
            Is pin number 6 of the IC 9238ch connected to ground? because when I open the datasheet, it's not ground?
              ASUS X415JA-EB1299T Notebook Specification for Upgrade or Repair
              This specification for the ASUS X415JA-EB1299T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X415JA-EB1299T boardview and X415JA-EB1299T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-07-2024, 05:50 AM
              ASUS X415JA-EK1008T Notebook Specification for Upgrade or Repair
              This specification for the ASUS X415JA-EK1008T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X415JA-EK1008T boardview and X415JA-EK1008T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-07-2024, 01:30 AM
              ASUS X415JA-EK1014T Notebook Specification for Upgrade or Repair
              This specification for the ASUS X415JA-EK1014T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X415JA-EK1014T boardview and X415JA-EK1014T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              ASUS X415JA-EB583T Notebook Specification for Upgrade or Repair
              This specification for the ASUS X415JA-EB583T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X415JA-EB583T boardview and X415JA-EB583T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
              09-06-2024, 11:40 PM
              ASUS X415JA-EB240T Notebook Specification for Upgrade or Repair
              This specification for the ASUS X415JA-EB240T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X415JA-EB240T boardview and X415JA-EB240T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
