Buying EC proggrammer
  • koby058
    • Jan 2017
    • 387
    • israel
    Does any one bought from any of those stores and lived to tell ?
    Are those stores reliable ?
    https://shop.svod-project.com/
    https://www.vss.store/
  • reformatt
    • Feb 2020
    • 1450
    Re: Buying EC proggrammer
    I got my SVOD3 from the SVOD store. Did take a month or so, and things are taking a bit longer last order I did due to the war over there I think.
    • koby058
      • Jan 2017
      • 387
      • israel
      I've bought the Vertianov successor from the VSS store and got it today
      Good service.
      Safe to buy
      • kingthink
        • Nov 2022
        • 19
        • China
        Does it take you that long to shop online? Purchased from abroad?
        In China, things bought online usually arrive the next day or every other day. There are relatively few arrivals on the same day, and only Jingdong can, because Jingdong has many warehouses all over the country. It is almost impossible to meet the situation that the goods arrive more than one week. If the goods arrive after one week, you will receive compensation.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You get delivery in a day ot two when you buy within your country but it does takes weeks when you're buying it from a store abroad ven though online.
          • koby058
            • Jan 2017
            • 387
            • israel
            It was purchased from abroad
            This store location is in Russia.
            Can some one please explain me what is the DMI data related to EC ?
            • volinakis
              • Jan 2021
              • 2809
              • N/A
              I did try to buy from vss.store and they don't accept payments from abroad. or the russian bank they are working with due to the collapse of their currency.
              • asustuf
                • Feb 2023
                • 18
                • Austria
                could you please check if your Vertyanov/SVOD support IT8225VG-128 chip?
                • Fam787
                  HELP! A1398 Dead,
                  by Fam787
                  I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
                  Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
                  12-27-2024, 05:19 PM
                  I bought three of these Sparkle Power FSP460-60GLC - Computer Power Supply 460Watts recap need
                  I have bought computer switching power supplies from Electronic Goldmine before and every one of them the capacitors were bloated and or leaking out of the capacitors so I am sure that these are going to be the same way five or six years ago I had bought some 300 and 350 watt computer switching power supply from Electronic Goldmine these are all from FSP brand
                  Here is the listing for this switching power supply they only had three of them in stock and I bought all three of them
                  https://theelectronicgoldmine.com/products/g28149
                  I have one old computer that...
                  07-18-2024, 06:55 PM
                  Another project idea for a battery bought from Battery Hookup with a good BMS board
                  https://batteryhookup.com/products/n...-2900mah-cells
                  One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
                  The price of this offer has gone up sense I bought these two boxes
                  I bought two boxes of these batteries but there is a catch to the these battery packs
                  The BMS protection board does work but it...
                  07-31-2022, 04:07 AM
                • xnRS
                  Did I just bought a fakecap ?
                  by xnRS
                  Today I bought... I mean friend of mine bought capacitors that I ordered, as the shop where i bought it is too far away from me, as he isn't understands anything in electronics, he just bought it as I ordered. At first shop on their page showed 1800uf 6.3V Sanyo caps, with generic picture and code SY-1800(which isn't correct). After little bit of search I found out that it was WG 8X20 capacitors(p.s found that out before buy). Ok, ordered, next day friend gives me package with those caps and some other caps that I ordered. But... This were NOT the Sanyo WG, these were Panasonic(Matsushita) FL...
                  06-01-2021, 07:48 AM
                  I just bought a SkyRc MC3000 battery testing machine very interesting device temp
                  I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
                  The charger has four individual temperature sensors for each battery cell
                  The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
                  Or test...
                  09-14-2022, 07:12 PM
