Samsung v25 screen and power problem
  • coolcurrent
    • Oct 2010
    • 98
    Hello guys,
    There is a samsung v25 am repairing that won't power on.
    if the power button is pressed, after 5 seconds, it would start beeping endlessly until i press the power button to off it.
    Even if it powers on, it will boot up to the windows xp desktop, then after some few minutes the screen will start having coloured vertical lines in red blue and then shutdown by itself
    any help here?
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsung v25 screen and power problem
    Sounds like a nasty problem. Take some pictures of it and post them here using "Manage Attatchments" on the post page. I dont think you should open it up and check the insides just yet, just post some pics of the failure "coloured vertical lines in red blue" .
    • coolcurrent
      • Oct 2010
      • 98
      I couldn't logon, as it continued with the sound i said ealier.
      what do i do now?. i suspect the ram
      • Wrog
        • Oct 2009
        • 472
        A couple of things I would try: once it successfully starts, try booting into Windows Safe Mode to see if the vertical lines persist. You could also use a Linux Live CD to test our the hardware. The reason Dgtech wants pictures of the vertical lines is to make a determination if there is an issue with the LCD panel itself or the video hardware on the laptop.
        If you suspect the RAM, try to swap out with some known good, or if you have a pair of sticks try them one at a time to see if things get better.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          Another thing to try would be an external monitor to see if the problem moves to it.
          • coolcurrent
            • Oct 2010
            • 98
            ok thanks guys, i opened the laptop and swap the 256mb ram to the other slot, then laptop came on
            i noticed one of the fans never spins even when doing heavy work with the laptop like watching films etc
            I did general dust cleaning, and remove all dirt blocking the ventilation airways. i the switch the laptop back on.
            I have been using it now for three days, and it seems to work fine. thanks for all who contributed, i will post any errors i notice.
            • coolcurrent
              • Oct 2010
              • 98
              Hello guys,
              I noticed a problem.
              When the laptop goes into sleep, and i press the power button to wake it up, it does wake up, but the screen doesn't display anything, but is lit with white light.
              pressing the keyboard or mouse doesn't make it show anything in the screen, but randomly pressing the keyboard makes the usual window error sound.
              I have to press the power button to do a hard shutdown, and then turn it on again.
              when the system does startup, it looses sound. I can temporarily restore the sound by first un-install the sound driver and installing again before i can get sound.
              this has happened three times, and am already sick of it.
              is the any solution?
              • Orpheous
                • Oct 2010
                • 43
                Hi coolcurrent,
                Maybe check your startup entries for possibly conflicting power management software, and disable. (msconfig, not startup folder)
                Reset the BIOS to defaults, then check your BIOS sleep states (S1, S2, S3 etc.) and adjust appropriately.
                Test the fan and it's connectors, replace/repair if necessary.
                Monitor the temps and put it to sleep, then try to wake it up. Then increase airflow, monitor temps and repeat... does it make any difference? If so, clean/replace fans and consider reseating heatsinks with Arctic Silver 5.
                • coolcurrent
                  • Oct 2010
                  • 98
                  Hello guys,
                  On trying to trouble shoot the problem, i got it to work fine for a moment.
                  the next day turning on the system boots to the desktop, and displays the following screen in the picture.
                  sometimes, as soon as windows boots up, it will display the desktop for about five minutes and shuts down by itself, at other times, it will just go off without shutting down!
                  what could be the problem?
                  • Orpheous
                    • Oct 2010
                    • 43
                    If I had to guess I'd say that the graphics chip/card is overheating due to a faulty fan/connector. That's assuming that you've done all the checks that have been suggested already...
                    Did you find out where the fan that doesn't work is connected to? It's probably the graphics card/chip
                    • coolcurrent
                      • Oct 2010
                      • 98
                      Thanks Orpheous for replying, I suspect the same thing though. I openned the laptop and removed the fans, air cleaned it thouroughly and replaced it.
                      Normally only one fan spins on startup, but when doing heavy processing like dvd rom related or playing video, both fans should spin, but it randomly does.
                      The problem is noticed when only one fan is spinning or non does
                      Any more troubleshooting suggestions would be appreciated
                      thanks
                      • coolcurrent
                        • Oct 2010
                        • 98
                        Hello guys
                        Now the lapto simply just goes to hibernation after logon. it does so for about 4-6 times before it stays 30min after logon and the hibernating by itself.
                        My observation is that the fans are not working correctly. How do i fix this problem?
                        • coolcurrent
                          • Oct 2010
                          • 98
                          I partialy solved the problem by reformatting the system now the graphics sucks i opend a thread for this https://www.badcaps.net/forum/showthread.php?t=11982
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • mrtek
                            Samsung UN43NU6950FXZA No power
                            by mrtek
                            Hi
                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                            Main fuse = OK
                            Back light LED = OK. Power them with aux power source
                            LED output = OK 156V
                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                            07-20-2025, 08:06 PM
                          • domu
                            Viewsonic VS16217 strange problem - white flickering screen on power up
                            by domu
                            As per subject, on power up display shows no image, but white
                            flickering screen. Strangely, it only happen after power was lost
                            when it was on. After power returns - white screen only, but if
                            disconnect power for 12-24 hrs, and connect then again monitor
                            works normally.
                            Any clues how to go about it would be greatly appreciated.
                            07-18-2023, 04:57 AM
                          • theone111
                            by theone111
                            3. Problem: TV shuts down
                            07-22-2024, 10:36 AM
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
