Latitude 5289 - Not working on known good battery
+ More Options
Posts
  • Prott
    • May 2022
    • 154
    • Czechia
    Hello friends,
    I am currently troubleshooting a problem with Dell Latitude 5289's motherboard.
    First the laptop had a short on the 5V rail (fixed by replacing a shorted cap). However after that it randomly didn't want to start on the battery power - this got worse to the point that now the laptop won't start when powered by battery at all.
    - The battery is checked and ok
    - If I start the laptop with a plugged charger it shows valid battery data (charge, cycles, etc.).
    - The laptop doesn't have problems charging the battery
    - If I unplug the charger while it is on it immediately shuts down (even if battery is shown as full)
    Recently I also started to experience random shutdowns while powered with a charger.
    Does anybody have an experience with similar type of fault? What could cause it?
    I have a spare board that I can transfer stuff from for troubleshooting, but I would like to first know where to start looking. :-) My first instinct would be to replace the two main mosfets and (if it doessn't help) the charging IC, but the fact that battery is still charging normally is kinda throwing me off.
    Thank you SO much.
  • mon2
    • 14449
    Re: Latitude 5289 - Not working on known good battery
    Remove all power. Meter in resistance mode. Check the resistance of each and every mosfet in the power path for the adapter; then again for the battery.
    Measure:
    source & drain
    source & gate
    gate & drain
    Post each measurement. Checking for a low resistance value for the mosfet = defective.
    Are you using the official Dell power adapter with the proper rating ?
    • Prott
      • May 2022
      • 154
      • Czechia
      Thank you so much mon2!
      I measured some weird readings on one of the two "main" mosfets (that PWR_SRC and CHARGER_SRC). So I decided two just replace both of them - now the laptop is working perfectly.
      The readings were:
      VIN -> Bg = 150+ kohm
      VIN <-> Vsw = 60+ kohm
      Bg -> VIN = inf
      Vsw <-> Bg = inf
      VIN -> Tg = 50+ kohm on the CHARGER mosfet, BATTERY mosfet inf.
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
        Another project idea for a battery bought from Battery Hookup with a good BMS board
        https://batteryhookup.com/products/n...-2900mah-cells
        One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
        The price of this offer has gone up sense I bought these two boxes
        I bought two boxes of these batteries but there is a catch to the these battery packs
        The BMS protection board does work but it...
        07-31-2022, 04:07 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
        DELL Latitude 5289 Hybrid (2-in-1) 5000 Specification for Upgrade or Repair
        This specification for the DELL Latitude 5289 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5289 boardview and 5289 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
        09-06-2024, 05:59 AM
