Lenovo IdeaPad 330 laptop mosfet issue
  • ebyte64
    replied
    Re: Lenovo IdeaPad 330 laptop mosfet issue
    I am sure you will be able to fix them.
  • mon2
    replied
    Awesome! Now, I just need some of that good luck to fix the units others have rejected around town. So much garbage out there..
  • ebyte64
    replied
    mon2, thank you so much for your help. It was the current sense resistor.
  • Vesko356
    replied
    Originally posted by ebyte64
    I wish I had a schematic for this board but unfortunately I do not.
    Originally posted by mon2
    PS: Is this the IDEAPAD 330S ? If yes, found the schematic in my paid service.
    Schematic ---> https://www.badcaps.net/forum/showth...26#post1215826
  • mon2
    replied
    Ok. To me, the path between ACN & ACP is too high.
    Measure the resistance from ACP to the mosfet Q5902 - should be 0R3.
    Then measure the resistance from ACN to the main power rail (C879) - should be 0R3.
    This is to confirm that the traces BEFORE and AFTER the current sense resistor are ok.
    The current sense resistor between ACN & ACP should be 10mohms = 10 milli-ohms. Respectively, with your meter, it should appear like 0R3. Only a very high quality milli-ohm meter can measure the true 10mohm value.
    Perhaps wait on others to comment but consider, if available, to replace the current sense resistor @ R5903.
  • ebyte64
    replied
    0.3 ohm
  • mon2
    replied
    What is the resistance if you short your meter probes?
  • ebyte64
    replied
    Ah thank you so much for the schematic. I only have the board with me right now but I will 100% sure if it is the right model.
  • ebyte64
    replied
    I get 1. 3 ohm between pin 1 and 2
  • mon2
    replied
    The charging ic used on this board is the bq24708s
    bq24780s ?
    This chip is well documented. Suggest to download the datasheet for this component for a deeper study.
    https://cdn.badcaps-static.com/pdfs/...2a8abce3d9.pdf
    Focus on the region with the current loop resistor. Suspecting that there is no fault in the 2*DCin mosfets nor the boost voltage required to enable each of the 2*DCin mosfets. That is, you have ~25v on the gate pin till both of the mosfets are soldered in place.
    Also, you know from the bypass method with an external DC power supply, the logic board works normally. The difference is that the charger IC is no longer involved in the decision making process.
    Respectively, the charger IC is involved once you restore the mosfets to be both onboard. It is very possible that the fault is in the current sense resistor circuit that follows these 2*DCin mosfets.
    Remove all power.
    Meter in resistance mode.
    Measure the resistance between the pins of the charger IC, pins #1 & #2 (ACP & ACN).
    Post the measurement. Be sure to measure directly at the charger IC and again, with NO power to the logic board / no battery attached.
  • ebyte64
    replied
    Thank you for your time the first mosfet behaves normally without the second mosfet on the board.
    First mosfter voltages:
    Drain: 19.6v
    Source 19.6v
    Gate 25.6v
    As soon as you add the second mosfet the voltage on source and gate becomes very eratic. 15 to 18v
    The resistances of the first mosfet :
    Drain to source 3.8m ohm
    Drain to gate 6m ohm
    Source to gate 3.9m ohm
  • mon2
    replied
    Link the schematic if available in the schematic forum.
    What is the charger IC on this board? This charger IC will drive the gate pins of the 2*DCin mosfets.
    Does the first mosfet behave normally if the 2nd mosfet is removed? Post the voltage to ground of each pin on the 2*DCin mosfets.
    Source
    Gate
    Drain
    Then remove all power. Meter in resistance mode.
    Measure the resistance of:
    Source and drain
    Source and gate
    Gate and drain
    Pins of each mosfet, while each is on the board. If the mosfets are known good then the fault is elsewhere but need to study the schematic.
  • ebyte64
    replied
    The resistance measurement after the second mosfet is 5.6 mega ohm. I have just to test bypassed both mosfet and the board does come on then and I can boot into windows. But that was just to test I will of course not leave it as is. Also the mosfet I have used are known good. I did check them beforehand.
  • mcplslg123
    replied
    Very likely one of the mosfets is shorted or leaky near charging coil. Check them one by one. 2 mosfets for charging coil(Upper and Low side) and another for discharge has to be checked in resistance mode.
  • mon2
    replied
    Are the mosfets known good and of the same type? That is, N-channel mosfets?
    Remove all power. Meter in resistance mode.
    Check the resistance to ground of the main power rail that follows the 2nd DCin mosfet.
    What is the measurement?
    PS: never bridge the mosfets. If it could be done, the vendor would have done so to save a few pennies.
  • ebyte64
    started a topic Lenovo IdeaPad 330 laptop mosfet issue
    Good day everyone.
    I have been scratching my head with a Lenovo laptop I got in today.
    The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
    Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
    Would anyone have any idea why?
  • Boxcryptor
    Lenovo - L340-15IRH Gaming Laptop (ideapad) - Type 81LK BIOS issue
    by Boxcryptor
    I tried to update the BIOS version on my Lenovo Laptop L340-15IRH Gaming from BGCN29W to the latest version, BGCN36WW, as released on the pcsupport.lenovo website. However, I encountered the following error message after following all the steps carefully:
    **InsydeH2O – Secure Flash**
    **Error: Decompress failed!!!**
    **Please press any key to reset the system.**...
    10-31-2023, 05:55 AM
  • alex26
    Lenovo ideapad gaming 3 laptop. I did a big mistake
    by alex26
    Hello. I have a Lenovo ideapad gaming 3 laptop. I did a big mistake, more precisely I powered a laptop with 61V instead of 19V. I found a shorted coil and injected 1v. TPS65993 is heating up. I powered it through the rectangular plug, not through USBC. It is possible that this integrated circuit has burned out. I can't find a datasheet. TPS65994 can be found at Mouser but I don't think it is a good replacement. This TPS65993 is PD controller.Thanks. Motherboard code is HLG30 LA-L916P.
    05-06-2025, 01:37 PM
    Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
    This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-07-2024, 05:00 AM
    Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
    This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
  • PCFixBeyond
    NB6380A MB V3 board of Lenovo Yoga 7 14IRL ideapad laptop
    by PCFixBeyond
    Can someoen share me schematic/boardview of NB6380A MB V3 board of Lenovo Yoga 7 14IRL ideapad laptop? One of the ic named RW=AC seems faulty but cant find anywhere replacement ic. Thanks
    07-20-2025, 09:22 PM
