ITE8987E not work
  • pabloroggeri
    Electronic
    • Apr 2015
    • 90
    • Argentina
    ITE8987E not work
    Change the EC ITE8987E because it doesn't turn on when it receives the ignition signal, the 3.3V power line is ok. there was a 30 ohm resistor. When removing the ITE8987E the resistance increased to more than 5K ohm. I changed the EC for the same ITE8787E-BXA, the resistance is not low, however it does not turn on or there is communication with the EC BIOS 25X40, neither is the clock.
    Is it possible that it requires recording with a programmer like svod3 or something similar for the EC to work?
    I also programmed the EC bios 25x40 with a file that was sent to me over the internet but it still doesn't respond to the ignition command.
    The motherboard is EM_A8316C_272B_V1.0
  • minaedward
    • Feb 2021
    • 34
    • luxor
    Hi
    I have the same issue
    Did you found a solution yet
    • pabloroggeri
      Electronic
      • Apr 2015
      • 90
      • Argentina
      Originally posted by minaedward
      Hi
      Hello, no, I returned the laptop to the client a long time ago. It is difficult since there is no schematic diagram of that type of tablet-pc
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • hollox123
        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
        by hollox123
        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
        1. Laptop keyboard doesn't work
        2. The backlight on the laptop keyboard doesn't work
        3. The x2 side LEDs (red) on the laptop don't work
        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
        But I am strongly aiming that it is somehow a BIOS-related problem,...
        05-11-2025, 08:05 AM
      • resistor83
        lenovo 330s-15ikb, led num lock key always on and numbers don't work
        by resistor83
        hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
        I tried updating the bios but the problem remains
        https://s...
        05-29-2025, 08:06 AM
        DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
        I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
        If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
        One —>the LEDs might be bad
        Two —> the buck converter or regular might be bad
        Three —> the controller might not...
        08-08-2023, 05:12 PM
