Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Dell Vostro 15 3000 (i5-11th Gen) 3 Orange 5 White LED Code
  • q5q
    replied
    Re: Dell Vostro 15 3000 (i5-11th Gen) 3 Orange 5 White LED Code
    Very annoying, spent so long working on it too. I guess its good for learning at least.
  • mcplslg123
    replied
    I too has faced RTC circuit fully or partially shorted specially on dell's 10th/11th gen. Seems like a very common fault.
  • q5q
    replied
    I have tried removing/replacing/testing almost everything in RTC circuit with no luck, might just need to buy a new motherboard PCH likely dead.
  • mcplslg123
    replied
    +RTC_CELL_VBAT-Resistance is too low at 0.75K. Try what i suggested at post#43 and do check the dual diode as suggested by piernov.
  • q5q
    replied
    Type "RTC" as keyword in search box of schematic and search it. Remove all the caps one by one connected in RTC circuit and see if problem goes away. However, going by my experience, you are staring at a partially shorted RTC section of PCH. Boardview is a must to locate those caps. Do check resistance to GND on +RTCBAT. The link to schematic is not working, so cant be precise in suggestions. Btw, What is the resistance to GND on +3V LDO?
    +RTC_CELL_VBAT Res to GND is 0.750 Kilo ohm
    LDO_3V3 (Think this is what you want me to check is) is 54 kilo ohm to GND
    I have a boardview in Xinzhizao software
    Last edited by SMDFlea; 06-09-2023, 09:24 AM. Reason: Schematic link at post #42 fixed
  • piernov
    replied
    Dual diode can be leaky too.
  • mcplslg123
    replied
  • q5q
    replied
    Dell Vostro 3500 (LA-K033P) RTC Draining/LED Code
    I am making this thread as sort of a follow up thread to my previous one as issue on there was fixed. (https://www.badcaps.net/forum/showthread.php?t=119200)
    When the charger is plugged into the laptop the white light comes on for about 5 seconds then fades out, then it starts blinking 3 orange 5 white (CMOS battery error LED code). This happens regardless of if there is a cmos battery in or not. I did change the cmos battery and it turned on for 1 boot and it said date and time not set (was still showing LED error code at this time) ... then i took charger out and tried again, this time it didnt power on just the led code again. Before I put the battery in it was around 3.2V but when I took it out around 20 minutes later it had fallen to just below 3V.
    Things ive tried: bios flash, new cmos battery.
    Schematic: https://www.badcaps.net/forum/showth...65#post1216565
  • q5q
    replied
    Nope same thing with or without cmos battery, only when it’s not draining it turns on… then it drains and won’t turn on next time
  • mcplslg123
    replied
    You get display everytime when CMOS cell is not inserted ? Problem begins only when CMOS cell is inserted? If yes, you have problem in RTC circuit.
  • q5q
    replied
    Sorry for very late reply been busy, I have found the issue and replaced the 3V controller chip. It’s almost fixed i’d say, there was a cmos battery led code so I replaced it and got it to turn on once, it says date and time not set… i unplugged the power and tried again, no post just cmos led code. I have checked the voltage of the cmos battery before putting it in, it was 3.2V after the few minutes of it being in it was drained to 2.8V. Same thing happened with the old battery before but I just thought it was a faulty battery. I do have a one more spare but don’t want to waste it. Any help in finding why this happens will be very helpful now.
    PS. all voltages are correct on coils now
  • mcplslg123
    replied
    I dont think ram replacement can do this type of damage. You need to take a fresh approach to disgnose the fault. Start with checking resistance to GND on all coils,check the basic requirements of SIO, flash clean me bios,cmos reset to start with.
  • q5q
    replied
    Yeah motherboard is doing absolutely nothing now, all because a stick of ram?
  • mcplslg123
    replied
    PQG4 is highside mosfet for VCCIN_AUX.You can expect 19V at the drain of this mosfet but voltage on the other side will come after powered on.I think motherboard is not turning on at all now.If yes, then no point probing PQG4.
  • q5q
    replied
    Nothing shorted to ground
  • q5q
    replied
    Reflowed, 3VS and 5VS good, came up with no ram led, took out power cable, put in ram, put power cable back in, now no lights and no voltage on any coil. Took out charger and ram, put charger back in, no lights and no voltage on any coils, flashed back to original bios, still nothing. 19V comes in, I have kind of probed around and 19V goes to PQG4 mosfet but nothing comes out, not sure if this is the issue though.
  • q5q
    replied
    Well, I checked it and I pushed hard on it while powering the board and got no RAM error, so will reflow it later. Awkward
  • q5q
    replied
    It looks fine, I could probably go over it again later.
  • mcplslg123
    replied
    Resistance seems normal. The dc-dc converter soldering is fine??
  • q5q
    replied
    Sorry, I had flashed the bios back to the original to see if it was some how a bios issue, and then 5VS went to 5V and 3VS dropped to 0.04V. Then the 3 amber and 5 white LED started flashing again. Later I will reflash to a different bios and clean ME but I need to wait for my flux to arrive later in the day.
    I have tried reading the resistance to ground again on 5VS and 3VS rails.
    Im getting around 1.2 mega ohms on 5VS however it keeps climbing, I have no clue why this happens. Tried again and got 0.8 Mega ohms and climbing.
    Same kind of thing on 3VS. It starts at 20 kilo ohms and starts dropping quite fast.
    The board isnt powered. No battery plugged in or charger, not even cmos battery as it is on a daughter board
    SLP_S3 is 3.3V. After powering for some time 3VS has 0.725V
  • Boardview and Schematic Bot
    DELL Vostro 3490 Notebook 3000 Specification for Upgrade or Repair
    by Boardview and Schematic Bot
    This specification for the DELL Vostro 3490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3490 boardview and 3490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3490 Notebook...
    09-06-2024, 05:00 PM
    DELL Vostro 3590 Notebook 3000 Specification for Upgrade or Repair
    This specification for the DELL Vostro 3590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3590 boardview and 3590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3590 Notebook...
