Macbook Pro - stuck in 5V after replacing CD3217
  • ongobongo
    • May 2023
    • 58
    HI all,
    new member here, so hi to the community.
    I have a problem with a MacBook pro 13", A2251, board 820-01949, that is nagging me.
    The macbook had liquid spill and didn't work at all when i received it.
    I was able to get it back working by replacing a shorted cpu mosfet and a resistor on that line.
    It worked good after that with one fault: 3 usb ports worked as expected, one port didn't work at all, no voltage draw, nothing.
    The USB-on-board connector and the small usb-board of that port where both defective, so I replaced the on-board connector and used a new usb-board.
    Result was the same, 3 working ports, one completely dead.
    So I tried the next thing that came to mind, replaced the CD3217B12 connected to the faulty port, U3100_W in my case.
    Unfortunately, since then, the board doesn't work at all.
    The 3 usb-ports that worked before only draw 5V and the port that was dead before is still completely dead.
    I replaced CD3217 2 more times, with chips from different sellers, but still the same.
    I checked the resistors/capacitors around the area but couldn't find a suspicious reading.
    I thought about changing ISL9240 but the area looks clean with no obvious defects.
    Does anyone here has an idea where i should look at or what might be the problem?
    Thanks a lot
    Ongo
  • vla9imir
    • Apr 2022
    • 5
    Re: Macbook Pro - stuck in 5V after replacing CD3217
    on these boards, when replacing cd3217, you need to remove another chip from exactly the same board 820-01949-A, cd3217 from other macbook models will not work
    • xloomx
      • Oct 2020
      • 51
      • Argentina
      And why is that? the GPIO are programables by apple?
      Thanks!
      • mon2
        • 14620
        Customized versions of the power delivery controller created for Apple by Texas Instruments. Customization can be pinout / firmware, etc. Suggest to follow the guidelines the research conducted by other techs else the repair will fail.
        • xloomx
          • Oct 2020
          • 51
          • Argentina
          Thanks!
          • Adogabriel100
            where to get trusted CD3217. Problem with A2337 Macbook Air
            by Adogabriel100
            Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
            The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
            09-06-2024, 12:06 PM
          • Bmet
            MacBook Pro 13 inch A2238 M2 stuck on 5V
            by Bmet
            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
            04-02-2025, 05:02 PM
          • TechSplendid
            MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
            by TechSplendid
            Hi All,
            I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
            Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
            04-09-2025, 02:13 AM
          • Steven Pieter
            Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
            by Steven Pieter
            hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
            11-24-2024, 10:02 AM
          • defdjamel
            macbook pro 16" m2 pro- A2780 - 820-02890 stuck at 5v - 0A
            by defdjamel
            macbook pro 16" m2 pro- A2780 - 820-02890 stuck at 5v - 0A on all usb port and magsafe.
            all voltage:
            PPBUS_AON = 0V , diode : 0,4
            PP3V3_AON = 0V
            PPVIN_P3V8AON 0V
            PPDCIN_AON_CHGR = 5V
            PPVBAT_AON_CHGR_REG = 0V
            so U5200 not do the job
            on u5200 :
            PP5V_CHGR_SW = 4.5 v
            CHRG_GATE_Q1 = 0V
            1V8_SDA = 0V
            ​1V8_SDC = 0V
            i check u5200 diode on PHASE and LX pin -> 0.4
            i don't understand something ,
            sda and scl in u5200 are pulup by 1V8_S2 ( 0V)
            so can not communicate .
            1V8_S2 are...
            09-03-2025, 07:11 AM
