Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    #41
    Re: Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
    There is nothing. It looks like C7883 is burned.
    • mon2
      • Dec 2019
      • 13855
      Remove this capacitor. Test again without this component.
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        #43
        Now the U7800 is not hot anymore. Still 20V / 0.4A. Should I put the PCB back and test it again?
        • mon2
          • Dec 2019
          • 13855
          Sure. Not sure what the true current consumption is for a working board but test it to see if you can see the display power on logo.
          • martyjelen
            • Mar 2023
            • 127
            • Czech republic
            #45
            It works without any problem now. Just doing a time machine backup.
            Thank you very much again. Also thanks to piernov.
            • mon2
              • Dec 2019
              • 13855
              Excellent. This was a very good case and added to my knowledgebase.
              • JulioChuts
                • Nov 2022
                • 15
                • Brasil
                #47
                MacBook PRO A1989 won't turn on
                Hello everyone at badcaps,
                Today, I have a MacBook Pro A1989 on my workbench that is not powering on. While conducting some tests, I noticed that as soon as I connect the charger, I observed using a thermal camera that the T2 chip begins to heat up, reaching temperatures between 33 and 32 degrees Celsius. I've only measured the input voltages of 12V and 3V at the coil "L7660," but the expected 5V voltage at "L7600" is not present.
                I don't have much experience with this type of equipment; my repairs are mostly focused on common laptops like HP, Samsung, etc. This is why I suspect I might be measuring incorrectly.
                However, I would appreciate learning at least the basic measurements to see if I can fix this MacBook. Thank you in advance.
                • PITERPENY
                  MacBook A1989. Stuck in DFU and won't turn on!
                  by PITERPENY
                  MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
                  20 volts and 0.00 amperes
                  Does anyone have any suggestions?
                  It's possible that the problem is in the EFI (BIOS),
                  who has the EFI ROM file please share
                  01-11-2024, 07:43 PM
                • nosinformatica
                  Macbook Pro 13'' - A1989 stuck at 5v
                  by nosinformatica
                  Preface : My primary job it's not repairing logic board, so please excuse me.
                  The Macbook A1989 is stuck at 5v at 0.3A on three usb-c port, and in one port no absorption, so the incriminated chip may be the CD3125.
                  I'have read that these mac have two CD3125 in daisy chain.
                  How can i confirm my diagnose before reballing it? Someone have experience with this issue?...
                  09-29-2023, 06:29 AM
                • Bmet
                  MacBook Pro 13 inch A2238 M2 stuck on 5V
                  by Bmet
                  I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                  04-02-2025, 05:02 PM
                • Steven Pieter
                  Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                  by Steven Pieter
                  hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                  11-24-2024, 10:02 AM
                • ErinV
                  MacBook Pro A1989 820-00850-A not powering on
                  by ErinV
                  Hey everyone!
                  I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                  I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                  The diode voltages around all 4 CD3215's seem fine.
                  For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                  09-30-2024, 10:21 PM
