820-02020 No Display, No TPAD, No USB, No KB, Fast Fan Spin
  • Comp_Pro
    • Jun 2020
    • 33
    Hello All,
    This is a weird one. This M1 Macbook Pro was brought in for liquid damage. Customer was getting video only on external monitor. Most liquid damage was located around the backlight circuitry, namely the backlight capacitor bank. It was not too severe. Ultrasonic cleaned and about 3 corroded capacitors replaced. FP800 backlight fuse was also blown. Nothing down the line from the fuse is shorted. May have blown this fuse from overload during liquid being present.
    Also had to repair area of QD530 which is PBUS VOLTAGE SENSE. Repaired traces to RD531 and RD532 as well as replaced the resistors themselves. Also repaired trace for PIN 3 of this QD530 to pad of NO STUFF RD530. Voltages around the IC now measure as follows.
    1. 0
    2. 1.71V
    3. 12.01V
    4. 12.01V
    5. 7.35
    6. 0V
    Unfortunately I seem to still be at the same place the computer was when it was brought in. Turns on, chimes, displays on external monitor. However the following is missing or having issues:
    There is no display and no backlight. Backlight circuitry not producing backlight voltage.
    JP600
    4 EDP_PANEL_1V8_EN 1.07
    43 PPVOUT_LCDBKLT 0V
    44 PP3V3_SW_LCD_CONN 3.3V
    45 PP5V_SW_LCD_CONN 5.V
    46 PP5V_CAM 5.0V
    There is no trackpad. It does not click. I checked support voltages and they are present. I did not have enable voltage at pin 17 presumably since I had to disconnect flex cable to take measurements at the connector.
    JT400
    1 IPD_LID_OPEN_1V8 1.8V
    17 SPI_TPAD_EN_CONN 0V
    21 PP5V_S2_TPAD_CONN 5.01V
    25 PP1V85_S2_TPAD_ISNS 1.82V
    29 PP3V3_S2_TPAD_ISNS 3.3V
    There is also no keyboard activity
    though it is hard to tell for sure as I can only see login screen on my external monitor if I close the lid. I assume keyboard is not there since I can't boot into hardware test nor boot option menu.
    JT200
    1 PP1V85_S2_KBD_ISNS 1.84V
    27 PP3V3_AON_KBD_CONN 3.28V
    There is also no USB activity.
    I am using a USB-C adapter to view on external monitor via HDMI. Though HDMI and charging works fine, if I hook up a mouse or keyboard through my USB-C adapter the lights on either the keyboard or mouse do not light up. It is as if there is no USB activity.
    Fan is spinning full speed
    . I recognize this as a symptom from where there is no TPAD connected.
    Voltages around U7700 are fine.
    Voltages around U8100 also seem fine when compared to wiki article except for
    PCPU 0.61, article says 1.06B
    ECPU 0.61, article says 1.06V
    PPVDD_SOC_S1 0.68, article says 0.85V.
    I am however not sure if this is an issue or not as I found another forum post somewhere and the person's board measured 0.61V as well on the first two measurements. Unsure about what the usual measurement is for PPVDD_SOC.
    I am trying to figure out what the commonly shared issue to no avail. Your help would be greatly appreciated.
  • Comp_Pro
    • Jun 2020
    • 33
    Re: 820-02020 No Display, No TPAD, No USB, No KB, Fast Fan Spin
    UPDATE: Looks like it's a couple of dumb issues grouped together.
    There was a metal flake in the battery data connector so computer was acting like the battery wasn't installed. After fixing this, trackpad, keyboard, and fast fan spin are all fixed. No idea why Apple designed these M1s this way. If you are working on an M1 macbook keep in mind keyboard and trackpad will stop working without a battery present. You will also get fast fan spin.
    Display is still not working but now that it appears to be the only issue I'll be trying with a different display panel.
    • reformatt
      • Feb 2020
      • 1551
      You may want to have a look at this video from Rossman first before swapping the screen. In this one, his lid angle sensor (which used to be a simple Hall effect in other laptops) was liquid damaged. This now needs their MAC config software to calibrate it so of course you need a GSX login to do that.
      https://www.youtube.com/watch?v=fOzO...=LouisRossmann
      • Comp_Pro
        • Jun 2020
        • 33
        Thanks for heads up! Angle sensor was working when testing with external monitor. Could see a reaction. Really hope I don't have to deal with those new stupid angle sensors much.
        Good news is the macbook is fixed! No display was just a bad lcd. Replaced and now fully working.
        Thank you!
          Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
          This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          09-07-2024, 02:20 AM
          Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
          This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 09:30 PM
          Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
          This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
          This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 07:50 PM
          Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) 1 Specification for Upgrade or Repair
          This specification for the Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPIN 1 SP111-33 boardview and SPIN 1 SP111-33 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 08:40 AM
