Laptop MSI model MS-16P5 restarts with power supply
  • Jane
    • Aug 2010
    • 188
    Laptop MSI model MS-16P5, with installed Windows 10, restarts whenever I connect power supply - within a second or two the laptop restarts.
    (Without a charger the laptop works OK.) Another charger behaves in the same way.
    However when windows starts in SAFE MODE, laptop does NOT restart even with connected charger.
    Stop error log is not generated by Windows.
    So I have:
    BugcheckCode 0
    BugcheckParameter1 0x0
    BugcheckParameter2 0x0
    BugcheckParameter3 0x0
    BugcheckParameter4 0x0
    SleepInProgress 0
    PowerButtonTimestamp 0
    BootAppStatus 0
    Checkpoint 0
    Do you think it can be Memory problem?
    Anyone solved such a problem? What to do?
    Thank you
    Lad.
  • mon2
    • Dec 2019
    • 14350
    Re: Laptop MSI model MS-16P5 restarts with power supply
    Suggest to review the charger IC.
    Attach the power adapter. Meter in DC volts (30V or higher is ok) scale.
    Carefully, measure the voltage to ground of each pin on the charger IC @ PU3.
    Post your readings and their pin numbers.
    • Jane
      • Aug 2010
      • 188
      Thank you for your reply.
      Do you think it can be charger IC problem?
      The laptop is being charged without a problem when the laptop is in SAFE mode.
      Also is being charged without a problem when the laptop is OFF.
      Why do you think it can be charger IC problem?
      Thank you for help
      • piernov
        • Jan 2016
        • 4437
        • France
        Always exclude software issue first. Could be crashing while switching power modes (for GPU or something else).
        • mon2
          • Dec 2019
          • 14350
          It is only a thought but after the normal mode of Windows is loaded, the smbus / I2C bus driver will be operational. It is possible that a defective smbus interconnect is raising the fault.
          Often the charger IC is a root cause so best to review it to at least eliminate this part as a suspect. Symptoms like yours usually lead to a defective mosfet but the mosfet is driven by the charger IC so best to review the charger IC.
          • Jane
            • Aug 2010
            • 188
            @piernov: Yes, but how to exclude software issue regarding Windows 10? I know it works in Safe mode, but how to find out the culprit when running in normal mode?
            Thank you for help
            • mon2
              • Dec 2019
              • 14350
              To confirm, Windows boots in normal mode when using only the battery as the power source ?
              • Jane
                • Aug 2010
                • 188
                Yes, the windows boots in normal mode and Laptop works properly if only battery is used
                • mon2
                  • Dec 2019
                  • 14350
                  Remove all power. Meter in diode mode.
                  Check if PD4 and PD5 are ok.
                  • Jane
                    • Aug 2010
                    • 188
                    Why do you think that PD4 or PD5 could be faulty?
                    Tha laptop charges when it is OFF or in SAFE mode.
                    If PD4 or PD5 were faulty could the laptop be ever charged ?
                    Do you think it is hardware problem and not software problem?
                    Thanks again for help
                    • piernov
                      • Jan 2016
                      • 4437
                      • France
                      Disable everything running at boot, update drivers, remove drivers, try fresh install, try Linux, etc…
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3608
                        • slovakia
                        i will check all mosfets on powerline from dcin to battery. seems like issue when switch from battery power to charger power
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          It's possible, yes. I agree - first two mosfets and the battfet must be checked too.
                          @Jane - does the laptop work normally when it is only with the charger plugged in (no battery connected)?
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                          • Jane
                            • Aug 2010
                            • 188
                            @ktmmotocross: But how can you explain that the laptop charges when it is OFF or in SAFE mode?
                            @Vesko356:Without battery it restarts too
                            • mon2
                              • Dec 2019
                              • 14350
                              A rechargeable battery can be charged with a dc power supply.
                              A leaky mosfet can supply the voltage to recharge the battery pack.
                              https://www.youtube.com/watch?v=4VDtMUxIvow
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                That being the case, it's worth checking the DC IN charging jack - poor contact, cracked soldering etc, also the power adapter itself. This laptop consumes a lot of amps, so poor contact at the DC IN jack or/and faulty power brick can be the cause of such a behavior.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3608
                                  • slovakia
                                  what this guy show is from mine experience MINOR laptop batteries, mostly older and he dont show variable overcurrent protection. if u have depleted battery and u try charging with 2A, protection cut off terminals. so u must use 0.5A to be not cutting off until battery have maybe 10% to start accept higher charging current. And many of newer batteries dont even connect terminals until charging ic told to battery ic that can charge
                                  • flat-earther
                                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                                    by flat-earther
                                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                    Windows also shows ''Plugged in'' when charger is not connected.
                                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                    If I let battery run out and say it has 3% Windows will...
                                    06-24-2025, 09:32 AM
                                  • serious_electron
                                    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                    by serious_electron
                                    Hello Everyone!
                                    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                    06-28-2025, 02:57 PM
                                  • shamsudeen
                                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                    by shamsudeen
                                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                    07-19-2025, 07:14 AM
                                    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                    Narrow VDC applications where the system power source is
                                    either the battery pack or the regulated output of the charger.
                                    This makes the max voltage to the system equal to the max
                                    battery voltage instead of the max adapter voltage. Operating
                                    at lower system voltage can improve...
                                    11-05-2024, 04:43 PM
