Lenovo T470s Part Identification Please.
  • Dan20701
    • Sep 2020
    • 199
    • United Kingdom
    Hello, I have a burnt chip Lenovo T470s and I am unable to read what
    it says on the chip.
    Can anyone help me out please with a photo of the chip
    and maybe where to get one from, Thanks.
  • JaroTech
    • Mar 2015
    • 351
    Re: Lenovo T470s Part Identification Please.
    Hi, according to the schematic this part is T1, it is a TAIMAG IH-189-A component. You can buy it from
    https://www.aliexpress.com/item/1005002712708058.html
    • anhbanxoi
      • Sep 2021
      • 172
      • VN
      This chip can work even with the cover broken. Make sure you test everything before ordering the new one
      • Dan20701
        • Sep 2020
        • 199
        • United Kingdom
        Thank you both for your help much appreciated, I never realized until
        looking at the picture of a new chip that this one has a cover on it.
        This chip maybe ok after all, Thanks.
        • Michael Farrey
          • Apr 2023
          • 3
          I am new here and apparently, I am not able to start a new thread so I hope you don't mind If I ask a similar question here. I am also trying to ID a burnt chip on a Lenovo el432/el532 motherboard. Power Sup section.Thanks in advance for any help you can provide.
          • JaroTech
            • Mar 2015
            • 351
            Hi, @Michael Farrey PU401 is a SY8386BRHC. You can also check PL401 to make sure it is not open.
            • Michael Farrey
              • Apr 2023
              • 3
              @ JaroTech thank you so very much! will check pl401 for open. I guess the next thing I need to do is determine the orientation of the chip, which way it sits on the board. Every picture I could find of the board was low resolution. Thank you again!
              • JaroTech
                • Mar 2015
                • 351
                PL401 is connected to pins 2, 3 and 4.
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                • thxd43
                  Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                  by thxd43
                  Hello, first of all, excuse me, I am using the translator, English is not my native language.
                  I have a Lenovo ideapad 330S - 14IKB laptop.
                  The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                  02-23-2023, 08:37 PM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • NConstantinou
                  LENOVO LA-K052P PART IDENTIFICATION PART
                  by NConstantinou
                  Dear all
                  i have tis m/b with an ic mark AWW6SF which i am trying to find datasheet but i couldn't.
                  can someone help!
                  06-02-2025, 07:23 AM
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
