lenovo y530 dead ite replaced - problems
  • darckreign1984
    • 260
    • Romania
    Re: lenovo y530 dead ite replaced - problems
    + i succesfuly updated i think the EC - ite - editing platform.ini from bios update files.
    • darckreign1984
      • 260
      • Romania
      - if i connect battery first, and then charger, i cant start laptop.
      BQ24780S, dont enable the mosfet from dc in.
      - if i conect first charger thne battery, i can start laptop
      • mon2
        • Dec 2019
        • 14715
        Likely that you have a leaky mosfet.
        The sticky above by @Piernov is a must read.
        Often the 2nd dcin mosfet becomes defective.
        Remove all power. Meter in resistance mode.
        Check the resistance of each of the DCin mosfets.
        Check:
        Source & drain
        Source & gate
        Gate & drain
        Post each resistance measurement.
        After the above checks..
        Connect the adapter and battery in the mode that fails to power on. Meter in dc volts mode (20v or higher).
        Carefully check the voltage to ground of each pin on the charger IC.
        Post each measurement and the pin being tested.
        • darckreign1984
          • 260
          • Romania
          Check:
          Source & drain
          Source & gate
          Gate & drain
          pq201 first mosfet
          Source & drain 3.7mohm
          Source & gate 3.69mohm
          Gate & drain 0 mohm
          pq202 second mosfet
          Source & drain 4.1mohm
          Source & gate 3.75mohm
          Gate & drain 0mohm
          pu201 - BQ24780S_VDD
          1-10.99v
          2-10.99v
          3-0v
          4-0v
          5-3.26v
          6-2.79v
          7-27milivolt
          8-0
          9-10milivolt
          10-0
          11-3.29v
          12-3.29
          13-0.79v
          14-0.76v
          15-0.302v
          16-1.36v
          17-10.99v
          18-17.03v
          19-10.99v
          20-10.99
          21-1.36v
          22-0
          23-0
          24-5.99v
          25-19milivolt
          26-5.35v
          27-5.37v
          28-20v
          • darckreign1984
            • 260
            • Romania
            Maybe laptop dont like this battery anymore, and enter in a "failure freeze" a protect mode?
            Now that it's have too low volgae, laptop turn off after I connect the battery.
            I cant start it, i do t remove battery then charger, then Conect again charger.
            • darckreign1984
              • 260
              • Romania
              #26
              i see now that after laptop start - keyboard its not working, so must be related to battery connect
              • Sephir0th
                • Oct 2020
                • 1289
                We're slowly moving into a direction which fits to the issue. Could be a issue with the Battery-to-system-FET
                FairRepair on YouTube
                • darckreign1984
                  • 260
                  • Romania
                  #28
                  forget to atach schematics
                  • mon2
                    • Dec 2019
                    • 14715
                    Remove pr206 = ~4k resistor. Do not lose this part.
                    Power up again with the power adapter.
                    Check the voltage to ground of the ACDRV pin on the charger IC.
                    Is the voltage now ~25v ?
                    • darckreign1984
                      • 260
                      • Romania
                      #30
                      after removing pr206, laptop dont start.
                      pq201 dont receive voltage on gate pin.
                      • mon2
                        • Dec 2019
                        • 14715
                        That is correct since we have removed the voltage for the gate pins of the DCin mosfets by removing this 4k resistor.
                        Can you measure the voltage to ground on the ACDRV pin on the charger IC?
                        We are only checking to see if the charger IC is able to BOOST the voltage to the proper levels by removing a possible leaky mosfet which will cause the ACDRV to be lower or even 0 volts.
                        • darckreign1984
                          • 260
                          • Romania
                          #32
                          when i removed the resistor - i measured voltage on gate - pin 4 on pq201, and there was 0 volts
                          • mon2
                            • Dec 2019
                            • 14715
                            Yes, that is expected.
                            Measure the voltage to ground of the other pin of the removed resistor pad.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              PQ201/202-Gate & Drain resistance-0mohm. What do you mean by that? It doesnt make any sense. If your meter is showing o, then lower the scale to 200K and check again resistance between G-D
                              • darckreign1984
                                • 260
                                • Romania
                                #35
                                so 2 test
                                1 - without battery conecter
                                on pin 4 on pq201 i have 19.82V
                                pin 4 - 25.6v on pu201
                                test 2 - with battery conected - i charged on external charger
                                pin 4 - on pq201 -20.4v
                                pin 4 on pu 201 -20.3v
                                • mon2
                                  • Dec 2019
                                  • 14715
                                  Ok. Pin #4 is now the correct voltage to enable the DCin mosfets.
                                  You have a fault with one of these DCin mosfets that is causing the ACDRV voltage to sink to 0 volts. The charger IC is behaving correctly.
                                  As suggested above, remove all power and check the resistance of the DCin mosfets.
                                  Often the 2nd mosfet gets killed and needs to be replaced. You can confirm the state with the resistance checks. If the readings are low, the mosfet is defective.
                                  Source & drain
                                  Source & gate
                                  Gate & drain
                                  Post each measurement. Use lots of flux and heat enough to melt the solder under the mosfet. Be patient and the mosfet will dance in the melted solder. Then remove to replace.
                                  Once the resistance readings are ok, apply the removed 4k resistor onto the board again.
                                  • darckreign1984
                                    • 260
                                    • Romania
                                    #37
                                    I mean 1 megaohm. - on auto scale.
                                    I test in resistor mode. No in diode mode
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      #38
                                      Its still not clear to me. This is what you posted at#24
                                      pq201 first mosfet
                                      Gate & drain 0 mohm
                                      pq202 second mosfet
                                      Gate & drain 0mohm
                                      • darckreign1984
                                        • 260
                                        • Romania
                                        #39
                                        pq201 first mosfet
                                        Gate & drain 0 mohm
                                        pq202 second mosfet
                                        Gate & drain 0mohm
                                        The multimeter have auto scale - and when I measure, I put the resistance mode and here was 0 mega ohm.
                                        Open circuit.
                                        • mon2
                                          • Dec 2019
                                          • 14715
                                          Post a picture of the meter face measuring this pair of pins.
                                          If you leave the meter probes separated, do you see the same reading on the meter?
                                          Ok, see the picture above.
                                          Some corrections..
                                          That is not 0M ohms. The face shows O.L. = over limit. That is, the resistance is so high that the meter is unable to measure it.
                                          Take the measurement again and show the meter face. Is it the same??
                                          If you short the probes, the measurement is different?
                                          0M ohms statement is confusing, at least to me.
                                            Lenovo Legion Y530 Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion Y530 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Y530 boardview and Y530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Legion Y530...
                                            09-06-2024, 02:30 PM
                                            09-06-2024, 01:21 PM
                                            09-06-2024, 12:51 PM
                                            09-06-2024, 11:35 AM
                                            09-06-2024, 11:32 AM
