820-00165 no green light on the charger and no fan spin
  • mcnamj70
    • Oct 2022
    • 14
    • United Kingdom
    I am troubleshooting a Macbook Air and the SMC posts a voltage of 8.2V at PPBUS_G3H.
    Should I replace the SMC?
    Macbook appears dead with no green light on the charger and no fan spin.
  • mon2
    • Dec 2019
    • 14250
    Re: Macbook air logic boards 820-3437 and 820-00165 Backlight
    1) what is the exact 820-**** number of your logic board ?
    2)
    A key power rail, that is 3v42 is missing. It is this power rail that powers the single wire Dallas / Maxim Semiconductor LED controller and soft-turn on of the power supply. If the magsafe hood led is missing then this power rail is missing.
    After you post the logic board #, we can review this power rail but often it is the DUAL common cathode diode that often fails.
    Attach your power adapter and measure the voltage to ground of each of the pins on the dual diode that feeds the above regulator.
    Post each measurement.
    Update - see attached.
    1) Check D7005 voltage to ground of each pin.
    2) Check the voltage to ground of PP3V42_G3H. Suspecting that this power rail is missing or is very low.
    • mcnamj70
      • Oct 2022
      • 14
      • United Kingdom
      My board is the 820-00165A.
      Will check the supplies and get back to you...many thanks for your help.
      • mon2
        • Dec 2019
        • 14250
        Well noted. The above schematic is the same on your 820-00165.
        Do review the above critical rails. Only if this rail is present will the PPBUS_G3H start to function, etc.
        • mcnamj70
          • Oct 2022
          • 14
          • United Kingdom
          Re: 820-00165 no green light on the charger and no fan spin
          Voltages measured at input to Diode were 20.2v and 8.2v with 20.1v at output. The PP3BUS_G3H measured 3.43v at output.
          • mon2
            • Dec 2019
            • 14250
            These are good voltages.
            Clean the contacts of the magsafe connector on you logic board with IPA.
            Check or replace the LIO cable that mates the main logic board and the LIO board.
            If you have 3v42, then the magsafe head led should be lit.
            • reformatt
              • Feb 2020
              • 1414
              Check SMC_RESET_L and area around U5110. First entry in the repair.wiki for this model. Covers most of these issues, and this specific problem has been covered thoroughly in other threads.
              https://repair.wiki/w/A1466_2015-201...9D_MacBook_Air
              • vdrokko99
                MBP wont turn on Only green light on charger
                by vdrokko99
                I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                SMBUS_SMC_BSA_SCL 3.5V
                SMBUS_SMC_BSA_SDA 3.5V
                12-01-2024, 12:18 PM
              • jheunne
                a1278 820-2936a fan spin green light only help
                by jheunne
                hi there i have a macbook pro a1278 board 820-2936a no boot no dispaly only fan spin and green light. i seen some corroision on top starting to u4900 to u3890 i manage to clean it but still no luck to boot. i figure out that in pp15v t29 there is no available out voltage it shows only 0.6 volts only...
                10-24-2024, 04:19 AM
              • ahoonid
                820-00165 Random green light on charger
                by ahoonid
                Hey everyone,
                I have a MacBook Air 2017 with a weird problem. The MacBook was totally dead at first and the culprit was the C7430 capacitor which was obvious upon initial inspection as it had a fracture on its surface.
                The F7140 fuse was also blown so I changed them both. L7130 due to corrosion was also replaced. Now everything works again. Laptops turns on and everything seems reliable at this point.
                The only issue that I'm afraid might bite me in the ass later is the magsafe light as it randomly changes light from orange to green while charging. Other times...
                04-10-2024, 04:06 PM
              • MOSSEP
                Monitor Audio RSW12 - Green light, but no sound
                by MOSSEP
                Hi
                Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                I have already tried replacing all of the...
                01-26-2025, 08:33 AM
              • MOSSEP
                Monitor Audio RSW12 - Green light but no audio
                by MOSSEP
                Hi
                01-26-2025, 08:18 AM
