hi guys I have a problem with this laptop, in practice it regularly charges the battery but it doesn't turn on, I tried to bridge the power on the keyboard connector but it doesn't turn on, with the thermal camera I don't see any hot parts so they don't seem to be short, it could be a problem corrupted bios? the motherboard is da0zasmb8d0 rev D
Acer A315-21-94XR Charge but no power on
Tags: None
Re: Acer A315-21-94XR Charge but no power on
3.3v arrives perfectly on pin 27 (NBSWON#_R) of the keyboard connector -
I think it's an ITE EC chip problem, has anyone had a similar problem?Comment
Here is attachedAttached FilesComment
Thats boardview and not schematic.
Measure voltage on pin11/26/33/72/14/100/107/112/118/123 of KBCComment
Assuming...7 Photos -
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
by proxneoDear reader
TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component... -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... - Loading...
