Asus Rog Laptop new battery still 0% Biard issue?
  • irepair559
    • Dec 2022
    • 134
    Re: Asus Rog Laptop new battery still 0% Biard issue?
    sorry was typing while driving ��
    • irepair559
      • Dec 2022
      • 134
      What do you think ?
      • mon2
        • Dec 2019
        • 14220
        LOL on your previous post.
        Pin 28 will be the pin north of the dot marking.
        Pin #1 is to the left of the dot marking.
        Measure voltage to ground of pin #28 = VCC.
        • irepair559
          • Dec 2022
          • 134
          pin 28 measures 19v
          • mon2
            • Dec 2019
            • 14220
            Good VCC.
            Measure each pin on this charger IC with the battery attached. Proceed with care so not to short any pins.
            Post each measurement.
            • irepair559
              • Dec 2022
              • 134
              ok finally got to it
              • irepair559
                • Dec 2022
                • 134
                what do u think ?
                • mon2
                  • Dec 2019
                  • 14220
                  The ACDRV pin #4 voltage is too low. It should be a boosted voltage of ~25v. This voltage output should be adapter voltage + REGN voltage, so 19v + REGN = ~25v.
                  With 20v only on ACDRV, the DCin mosfets between the adapter and main power rail will be OFF.
                  REGN pin #25 is at 0v and should be at 6v.
                  Remove all power, meter in resistance mode.
                  Measure the resistance to ground of the REGN pin.
                  Post the measurement.
                  Also, with no power, meter in diode mode.
                  Red meter probe, yes red to ground.
                  Black meter probe to the REGN pin #25.
                  What is the measurement?
                  Be sure there is no power to the board. Be sure you are on pin #25.
                  As mentioned earlier by other techs, you may have a leaky MOSFET that is causing these faults.
                  Concerned about the missing REGN rail. This often means the charger IC is defective and needs to be replaced. If you are not in a rush, AliExpress will have this part. When placing an order, also purchase the mosfets surrounding this charger IC. They are very inexpensive. Post pics of the mosfets that are driven by this charger IC.
                  For example, the ACDRV pin will have a ~4k resistor that will go to pin #4 of 2x mosfets. Those mosfets are also suspects. A leaky MOSFET will allow the board to power up but not charge the battery.
                  • irepair559
                    • Dec 2022
                    • 134
                    ok will do , and to save time ill buy 2 ics and pack of mosfets. The little square one or the larger ones? Also wheres the best place to buy these in the US?
                    • mon2
                      • Dec 2019
                      • 14220
                      Post the topside markings of the mosfets or clear pictures of the same.
                      Most should be available from Digikey / Mouser.
                      For the charger IC, TI has their own webstore as well. Wait till we build up a grocery list.
                      • irepair559
                        • Dec 2022
                        • 134
                        isnt pin 24 the REGN ? pin 25 is 5.8v
                        • mon2
                          • Dec 2019
                          • 14220
                          Correct, pin #24 = REGN. Be sure that you are measuring the proper pin.
                          Update the latest / corrected voltage to ground on pin #24.
                          • irepair559
                            • Dec 2022
                            • 134
                            pin 24 diode reading 0.52v
                            • irepair559
                              • Dec 2022
                              • 134
                              remember i mentioned that top area of the board where it had a burnt cap i removed. Do you think something up there is causing all this?
                              Also those mosfets are more down the board near the batt term.. They look really heated up and curved.. How do i test mosfets ?
                              • irepair559
                                • Dec 2022
                                • 134
                                what do u think brother ?
                                • irepair559
                                  • Dec 2022
                                  • 134
                                  anyone ?
                                  • mon2
                                    • Dec 2019
                                    • 14220
                                    To test mosfets, you can check the resistance between the pins of the device or check their diode mode readings. Found a great website that details both but let me summarize one method.
                                    Reference:
                                    https://electronicsbeliever.com/how-...-is-defective/
                                    Both methods must be with no power to the logic board.
                                    Checking in resistance mode is convenient.
                                    Meter in resistance mode.
                                    Measure the resistance across the mosfet pins as follows:
                                    Source (1-2-3) & Drain (5-6-7-8)
                                    Source (1-2-3) & gate (4)
                                    Gate (4) & Drain (5-6-7-8)
                                    Post each measurement. If the reading is low, the part is likely defective.
                                    • retrorepair2
                                      • Feb 2023
                                      • 75
                                      • United Kingdom
                                      #38
                                      Just since it's not yet been mentioned, this is also why your laptop is turning off before starting. You'll find the bios battery is also dead and not charging
                                      • irepair559
                                        • Dec 2022
                                        • 134
                                        Reference:
                                        ok it seems ike i found 2 bad mosfets?
                                        one right behind the charger port
                                        source grounded to drain
                                        the other small one near top of board where the cap burnt..
                                        Gate ( where dot is ) shorted to drain ( all 4 pins other side)
                                        gets 24 ohms beeps..
                                        • Sephir0th
                                          • Oct 2020
                                          • 1282
                                          Although it is a typical way how a DC-IN Mosfet shorts out, your resistance measurements does not makes sense at all regarding the previous observation.
                                          The two Mosfets on the first picture. What resistance do you measure between Source and Gate?
                                          The Dual-Mosfet near the burned via might be a secondary(!) issue which you might want to rule out later.
                                          FairRepair on YouTube
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • code share
                                            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                            by code share
                                            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                            Here's what I've tried so far:
                                            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                            • Booted successfully on AC power only with the battery disconnected
                                            • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                            • Battery
                                            04-21-2025, 12:50 PM
                                          • huzo
                                            HP ELITE X2 1013 G3 weird battery issue
                                            by huzo
                                            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                            01-31-2025, 12:09 AM
                                          • danielsak
                                            Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                            by danielsak
                                            Hello, I have issue with Dell Inspiron 3542.
                                            Motherboard marking:
                                            Code:
                                            PWB FX3MC REV: A00
                                            The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                            1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                            1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                            10-11-2024, 04:36 PM
