Dead ASUS ROG G14 (GA401)
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Dead ASUS ROG G14 (GA401)
    This is a classical behaviour of a shorted DC-IN Mosfet, between Source and Drain, for example
    FairRepair on YouTube
    • mon2
      • Dec 2019
      • 14199
      My bad, yes pins #4 & 5 which appear to be ok for the diode mode readings.
      Let us check that the contacts reach the charger IC.
      Meter in diode mode. Short the meter probes and you should have a tone beep.
      One meter probe on pin #4 of the battery connector (without the battery connected); other meter probe to pin #12 on the charger IC.
      Do you hear a tone beep?
      Repeat with pin #5 of the battery connector & pin # 11 on the charger IC.
      After the above tests, power up - still without the battery.
      Meter in DC volts mode. Measure the voltage to ground on pins #4 & #5 on the battery connector.
      You should have ~3v on each SMBUS SCL / SDA pin.
      Finally, connect the battery again and check if the voltage to ground measurements remain at ~3v on these battery contacts.
      A defective BMS board on the battery pack can cause the SMBUS communication to fail. At that point, the battery should be replaced.
      Post each measurement.
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        #123
        Connection between connector and IC is there.
        Both pin #4 and #5 show only 0.66V when DC in connected and pc turned on, also with battery plugged in.
        • mon2
          • Dec 2019
          • 14199
          This is in diode mode?
          Place meter now in dc volts mode.
          What is the voltage to ground with the battery and adapter connected for these smbus pins (SCL and SDA)?
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            #125
            No, DC mode
            • mon2
              • Dec 2019
              • 14199
              Remove the battery. Using only the power adapter, what are the voltage readings to ground of these 2 pins?
              • jacobtc
                • Apr 2016
                • 274
                • Denmark
                #127
                Both are 0.6V
                • mon2
                  • Dec 2019
                  • 14199
                  These are open drain pins so they must have local pull up resistors to park these pins to a soft logic high level.
                  Either these pins are missing these pull ups or the ESD diodes are pulling these pins low.
                  Locate the ESD diodes on these pins on the logic board. They should be fluxed and carefully removed. Do not lose the parts.
                  Then power up again and check these pins.
                  See attached for their component names.
                  • jacobtc
                    • Apr 2016
                    • 274
                    • Denmark
                    #129
                    Both are still 0.6V after removing diodes.
                    • mon2
                      • Dec 2019
                      • 14199
                      See attached. Locate these local pull-ups for this SMBUS pair of lines.
                      Confirm the voltage on each side of the pull-up resistors.
                      R3001
                      R3015
                      • jacobtc
                        • Apr 2016
                        • 274
                        • Denmark
                        #131
                        R3001
                        R3015
                        Thanks, the boardview is not the correct one, but I found one elsewhere, these are the resistors and their measurements (see pic).
                        • jacobtc
                          • Apr 2016
                          • 274
                          • Denmark
                          #132
                          Both DC-IN mosfets show normal behavior, 20V on S and D, 26V on G.
                          • Sephir0th
                            • Oct 2020
                            • 1282
                            This is not how you test a Mosfet for internal short between all three logics. But 25V at Gate points to there is possibly something else going on.
                            • jacobtc
                              • Apr 2016
                              • 274
                              • Denmark
                              #134
                              I know, both mosfets has been off and measured between S-D, G-D and G-S
                              • Mabot17
                                ASUS gaming laptop GL704GV GPU DEAD SHORT
                                by Mabot17
                                Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                05-10-2025, 11:04 AM
                              • ktmmotocross
                                Asus UX433FAC - batery dead after short on VIN rail
                                by ktmmotocross
                                Hello.
                                Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                                can that short shorted battery? batmon show that battery is full at 80%
                                12-29-2022, 12:06 PM
                              • OOF DIO
                                ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                by OOF DIO
                                (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                (Had 3 problems, now just 1)
                                I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                04-19-2025, 05:03 PM
                              • jkucukov
                                Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                by jkucukov
                                I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                02-05-2025, 09:27 PM
                              • Beton
                                Finding a dead short component
                                by Beton
                                Hi guys!
                                I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                I have a bench PSU and if I try to inject voltage the voltage...
                                12-10-2021, 01:05 PM
