ACER Nitro AN515-53-55H5 Keyboard problem
  • mferna14
    • Jun 2018
    • 1026
    Hi all., can anyone help me get this ACER Nitro AN515-53-55H5 (Motherboard LA-F952P Rev: 1.0) keybaord working. I replaced it with another main motherboard as my previous one had the power section burnt. The new motherboard works & boots up finebut the keyboard does not work at all. I know that the laptop keyboard was 100% working with the older motherboard & when I installed this new one, it does not sense any keys. The ON/OFF button is on the keyboard & it works fine. The keyboard neither works in the BIOS setup or Windows 10. I use an external USB Keyboard & it is working fine without any problem. On JKB2, which this laptop uses, I get 3.3v on most of the point. Is there 5v on any of the pins as I cannot measure 5v on any of the pins? Do you think the I/O chip is defective??? I need the help in this one, thanks for all the help in advance.
  • Bonzas
    • 471
    • Indonesia
    Re: ACER Nitro AN515-53-55H5 Keyboard problem
    If your keyboard work on bios even power button, maybe your proble is OS. does your touchpad working on windows ?
    • mferna14
      • Jun 2018
      • 1026
      Dear, "martha februarini" thanks for the reply, I think you did not read the motherboard error description well, I clearly said it "keyboard neither works in the BIOS setup or Windows 10". This is where I am having problem. Thanks replying back.
      • mon2
        • 14255
        No 5 volts since the KBC is the scan controller and the GPIO are at 3v3. Confirm the interface cable is firmly seated. The mating connectors are soldered on the logic board. The replacement keyboard is for sure compatible?
        Are you able to test the original keyboard on this box?
        Does the keyboard backlight work? The enable for the backlight is also invoked by the same KBC IC. The firmware is inside this device.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          It seems new mb is not faulty as you have 3.3V on many pins and power button of kbd is working is sure indication of keyboard being powered. Keyboard fail very often. I'll strongly suggest to replace the keyboard first even though you assumed it was working 100%. Before trying out a new kbd, its not advisable to mess up with EC.
          • Bonzas
            • 471
            • Indonesia
            sorry i didn't read carefully, i think i'm sleepy when read your description. i'm facing problem like yours many times cause dry solder join from keyboard connector and pull up resistor form keyboard to kbc.
            I agree with mcplslg123, just check again before mess up with kbc. Try to resolder keyboard connector or pull up resistor if they're exist on your keyboard
            • sikocan
              • Oct 2019
              • 344
              Do you have a keyboard tester to use?
              • mferna14
                • Jun 2018
                • 1026
                Thanks for all yous tips & answers, I do not have a replacement keyboard for this ACER model. One thing more, I do not physically see any pull-up resistors, the circuit is directing going into the KBC. I will take another with a 30-pin connector & attach it to this motheboard. Let me see what happens. It should print characters when pressing any or all the buttons. This might proof that the KBC is working & the keyboard is faulty. Let me check today. Thanks all.
                • mferna14
                  • Jun 2018
                  • 1026
                  The Keyboard backlight is ON, & turns on very normal.
                  • mferna14
                    • Jun 2018
                    • 1026
                    Just for fun sake, I carefully removed the IO (KB9022Q) chip from the old motherboard & installed it in the new MB, still same error, keyboard does not work all. I cannot try another keyboard because I do not have a 28pin cable keyboard. Keyboard is totally dead, only ON/OFF button & Keyb Backlight works 100% fine. Do you think any SMT chip or component inside the keyboard which is not allowing the keyboard to power on??? Any tips will be appreciated. Thanks in advance
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Why waste so much time and energy in troubleshooting a keyboard issue?? Just order a new keyboard. You are residing in Canada where it is very likely available atleast online.
                      • mferna14
                        • Jun 2018
                        • 1026
                        Yes "mcplslg123", I will just order a New keyboard today... Good it not too costly.. Hopefully this might rectify the problem. Thanks, will surely keep you updated.
                        • reformatt
                          • Feb 2020
                          • 1414
                          Acer keyboards are total crap and fail regularly. Especially the ones with integrated power buttons.
                          • mferna14
                            • Jun 2018
                            • 1026
                            Thanks @reformatt for the information. I have ordered another keyboard, once confirmed that this keyboard is defective I will inform you guys. I will surely tear apart the keyboard to see what is going wrong with the old keyb if faulty.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Agreed.What about Asus kbd?? I think they are even worst then acer.
                              • reformatt
                                • Feb 2020
                                • 1414
                                Acer and Asus are the two brands I tell everyone to avoid.
                                I was in Harvey Norman the other day (a big electrical retailer here in Oz). I was waiting on the other half and standing in the computer section in front of a couple of Acer/Asus machines. Young sales kid asks me if I'm interested, and I said these are the two brands I tell everyone to avoid. So he asks what would I buy?? I said nothing you sell in here. And he asks me why. Suffice to say after 5 mins his eyes were spinning.
                                • rediii
                                  h???, spurrrn
                                  • Mar 2018
                                  • 487
                                  • somewhere in europe
                                  you are right. especially asus zenbooks are real crap. have had so many of these machines with broken traces. they are the most sensitive ones i have ever seen when it comes to this type of failure. acer machines sometimes have the weirdest logic failures though...
                                  • mferna14
                                    • Jun 2018
                                    • 1026
                                    The question is HOW DOES THIS KEYBOARD GO TOTALLY DEAD???? Hope this is the problem, then I will tear apart the old one & check what goes wrong with them, how does it get totally dead & not a single key work. May the GRD trace might be burnt or cut off due to some reason. Hopefully this is the problem. The new keyboard is on it's way, might receive it within these days, I will keep you guys updated. Thanks
                                    • mon2
                                      • 14255
                                      suffice to say after 5 mins his eyes were spinning.
                                      lmao
                                      • reformatt
                                        • Feb 2020
                                        • 1414
                                        I have seen an issue on a HP Probook where the keyboard didn't work because of the WIFI button assembly. I actually replaced the EC on that one, had it all working only to find keyboard not working when I reassembled it. When disconnected, the keyboard began working. I sent it back to the shop it came from and they replaced that board which fixed it.
                                        So just make sure you have everything else not essential disconnected to rule it out. Be surprised if the KB didn't fix it, they are truly awful.
                                        • fmajbour
                                          Acer Nitro 5 model A515-51 keyboard problem
                                          by fmajbour
                                          I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                          Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                          i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                          I have check the keyboard connector on the mainboard every thing looks ok.
                                          Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                          I need your advice if anyone face...
                                          11-13-2023, 09:50 PM
                                          ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:28 PM
                                          ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ACER NITRO N50-110 NITRO 50 3500 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO N50-110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO N50-110 boardview and NITRO N50-110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                          ACER NITRO N50-600 NITRO 50 i7-8700 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO N50-600 boardview and NITRO N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
