Acer Swift SF314-54 charging, not powering up
  • Sephir0th
    replied
    Re: Acer Swift SF314-54 charging, not powering up
    Am I the only one here who have issues with the pictures shared here? They're way to small. I can't identify anything
  • kuupotin
    replied
    Originally posted by mon2
    It is risky to use voltage injection too early till we know more about the state of the logic board.
    What voltage was used for the voltage injection?
    1V, 2A limiter
  • mon2
    replied
  • kuupotin
    replied
    Remove all power. Meter in resistance mode.
    Check the resistance to ground of each and every coil / inductor on the board.
    Each such coil / inductor is linked to a local power supply rail. If the resistance is low, there is a shorted part (capacitor??) on that rail needs to be removed / replaced.
    Otherwise the low resistance is being sensed by the current sense loop and forcing that local regulator to power OFF to prevent further issues.
    Checked every big inductor. There was two low resistance ones and two slightly higher. Voltage injection didn't gave any hint. CPU is heating a little, good or bad sign?
    Coils on lower left side of cpu.
    Voltage injection to this coil. Lowest resistance to ground.
  • mon2
    replied
  • kuupotin
    replied
    Originally posted by kuupotin
    Cannot switch board. After powering 3V_EN stays 3.3V few seconds (PU4501 pin12).
    No life in 3V_5V_POK and PWR_3D3V_PG
    I mean that board doesn't stay powered, only few seconds. No status change on power led, stays off.
  • kuupotin
    replied
    Measurement is good. What about 3V_EN/3V_5V_POK/PWR_3DV3_PG ? You may need to switch the board to take measurements.
  • mcplslg123
    replied
    Do you mean PWR_3D3V_LDO?
    This was 22k when measuring from PR4501 pin 17 to ground. I noticed that 3.3V was present.
  • kuupotin
    replied
    Since you have schematics, measure resistance on 3V LDO(LP). It should be measured without any power connected.
  • mcplslg123
    replied
  • Bonzas
    replied
    I have everything. Tools, hot air, soldering tools etc Actuallu just loaned a thermal camera from friend.. Replacing components is not a problem.
    Just thinking that is it a correct component? It is slightly warm when powering and cools quite fast. Mobo takes a low current spike before shuts down.
    So you need to make sure again if all voltages present. You may need read carefully on schematic that show power squence on your board. Where is coil or pad that doesn't have output voltages. Some chip have pwrgood signal to communicated with other part
  • kuupotin
    replied
  • mon2
    replied
    Come on over to the dark side and help us repair more crapware.
    Do you have a hot air tool? Flux? Tweezers? Perhaps a dead board for training?
    If not, can send you some links for such tools.
    If you are not in a rush, this QFN package is simple to replace.
  • kuupotin
    replied
    Thanks.
    Looks like PU4501 (SY8288BRAC-GP) is heating a little bit when powering mobo by shorting pins.
    I have a very little of experience with mobo repair. I have fixed some mobo by voltage injection and checking which component is heating.
    This thing is a lot more difficult.
  • Bonzas
    replied
    No schemas. Strongbow_kbl_mb 17863-1
    Found 3.2V from keyboard connector. Tried to start board by shorting two outermost pins, no change in coil voltages.
    Schematic here
    https://www.badcaps.net/forum/showth...13#post1203113
  • kuupotin
    replied
  • Bonzas
    replied
    Applied 19V to power connector and get these kind of measumements. All other coils are zero. This without pressing power button. Couldn't find 3.3V rail...
    What do you mean can't find 3.3v rail ? do you have schematic or boardview your motherboard ?
    code board ?
  • kuupotin
    replied
  • Sephir0th
    replied
    I'd start with a basic overview of the power rails of the board. Which voltages are at coils present without pressing the power button, which are present while/after pressing the power button. What resistances to GND (range 200) do you measure at the various coils. Like that, to start with. Assuming a basic understanding of how to use a multimeter.
  • kuupotin
    started a topic Acer Swift SF314-54 charging, not powering up
    Hi all.
    I have Acer Swift SF314-54 which is charging (after battery reset, red charging light which turns blue when full) but when I'm trying to power it up by pressing power button, nothing happens. Actually if laptop is connectec to PSU and blue charging light is on and I'm pressing power button, blue charging light turns off. After this I have to make battery reset again to get blue light back.
    Also when psu is not plugged, there aro no lights on led. No lights when power button is pressed. Never seen light in power led.
    Mobo looks very clean without any water etc damage. I'm not able to power laptop from mobo by shorting keyboard edge pins when ribbon is not connected.
    Where to start?
    Tried to reconnect every ribbon and connector on mobo, no luck. Bios battery changed. RAM, SSD etc, no luck. There is surely something wrong on mobo.
    There are some shorted capacitors near cpu but that might be ok.
    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 05:00 AM
    Acer Swift Swift X Notebook X Specification for Upgrade or Repair
    This specification for the Acer Swift Swift X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift X boardview and Swift X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Swift...
    09-07-2024, 02:20 AM
    Acer Swift Swift 1 Netbook 1 Specification for Upgrade or Repair
    This specification for the Acer Swift Swift 1 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 boardview and Swift 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Swift Swift...
    Acer Swift SF114-34-P5YB + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
    This specification for the Acer Swift SF114-34-P5YB + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P5YB + Pack Gold Acer 14'' boardview and SF114-34-P5YB + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    09-07-2024, 03:10 AM
    Acer Swift SF314-43-R9W7 + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
    This specification for the Acer Swift SF314-43-R9W7 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R9W7 + Pack Gold Acer 14'' boardview and SF314-43-R9W7 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
