ASUS x421IA board, IT5125E
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Hello guys.
    Have this board with heating:
    IT5125E-128
    2120-CXA
    And cant find if this chip is programable or i can just buy from Ali and change it?
    And what CXA stands for? Because some sellers offer same chip on both codes with CXA and without CXA. Other sellers offers two diffrent variations, one with CXA another without CXA.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS x421IA board, IT5125E
    This SIO is programmable and you need a programmer like SVOD etc to do the job. Its wiser to match the suffix as well.
    • zpi
      • Feb 2018
      • 132
      • Lithuania
      As i always worked only on macbooks, still don't have programmer for SIO chips, probably my original GQ-4x4 will not work on them ? What would you recommend from cheaper ones ?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        There are cheap clones of veryanov sio programmer available online but dont know about there performance or reliability. I use SVOD though i do have 2 more sio programmers and one is cheap clone of veryanov.They sometimes program correctly but sometimes gives weird error messages-I dont fine them reliable. Moreover,they are good for older ITE/ENE series and most often then not fails to program newer ec.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          Is it normal that aliexpress is showing me sio programmers for 700-1000$ ? Thought they should be cheaper Can you share name of cheaper one ?
            • 21932
            SVOD4 https://svod-project.com/en/ .They have a list of partners that you can buy from or buy direct from them.
            The other option is the vertyanov SUCCESSOR .Due to the stupid war i`m not sure if you would be able to buy or not,as they are in russia,send them an email if you prefer this one.
            https://www.vss.store/
            • zpi
              • Feb 2018
              • 132
              • Lithuania
              Just to be sure, i have GQ-4x4, this one is not capable for programming SIO if i connect directly to pins on SIO ?
                • 21932
                Don`t think so,here`s the support list http://www.mcumall.com/comersus/stor...supportICs.asp
                One other programmer i forgot to mention is the RT809H
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  ENIT Sio programmer-This is a cheap clone of veryanov. Its available in india at INR7000.00(1$=80INR)
                  • lord
                    • May 2011
                    • 319
                    • Croatia
                    i have one of these clone vertyanov but cant never get it to work
                    • moshu
                      • Oct 2024
                      • 66
                      • Ireand
                      Hi SMDFlea
                      I am looking to buy a decent programmer to remove BIOS password on Lenovo e15 and not sure which one I should buy and from where to buy.
                      Reading here, I see there are 2 options, svod and vertyanov SUCCESSOR so which one do you recommend?
                      To remove BIOS password on Lenovo e15 I've try and succeeded the " Lenovo Thinkpad Ec Pwd Bypass" but is time consuming and may work on few units but I need something faster than that and reliable.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • DynaxSC
                        ASUS STRIX Z490-F GAMING - No POST, stubborn board
                        by DynaxSC
                        I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                        The situation looks like this:
                        After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                        1. RTC oscillates normally (32.768KHz).
                        07-08-2022, 05:45 AM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • ShadowAi12
                        ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                        by ShadowAi12
                        I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                        • The board enters a "ready to power on" state after plugging in the PSU.
                        • Pressing the power button increases power draw.
                        • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                        Measurements:
                        (taken after pressing the power button, while the board is attempting to start)
                        • H_SKTOOC#
                        06-11-2025, 01:05 PM
