Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Asus Q551L Not Charging
    Posted Photos 12 Photos
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • ahmarzo
    Asus x513ea laptop charging problem
    by ahmarzo
    Have Asus x513ea laptop motherboard with charging problem.the laptop shows 0 percent but charging not increasing.when adapter and battery is connected the battery connector shows 1.5 v on the scl pin no 5 and sda pin shows 3.2v .have changed resistor pr6005 and charging ic but problem remains same.have tried another 2 new battery but there is always 1.5v on scl pin.
    Help me solve this problem please .
    https://www.badcaps.net/filedata/fetch?id=2105951
    12-29-2025, 08:39 AM
  • ronaldopdias
    ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
    by ronaldopdias
    I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
    • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
    • BIOS file downloaded directly from the official ASUS support page.
    • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
    Issue:
    The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
    Because FlashBack didn’t work, I:
    • Removed the BIOS SPI IC from
    02-04-2026, 03:16 AM
