La-c701p
  • pippo_one
    • Aug 2010
    • 120
    • Vicenza
    La-c701p
    Hi All
    I have a mainb HP LA-C701P which has exploded the mosfet Q30
    and once unsoldered the rubble of the mosfet I found a short to ground of the DRAIN
    not having any serigraphy in the pcb I can't determine the value of this capacitor to which I post the photos, this capacitor is shorted to ground.
    I tried to measure the size of the component and for me it is a 0804 while in the wiring diagram if that turns out to be a C590 the specifications tell me that the component is from the 0402 family
    I ask for help and confirm if the capacitor in that position is the C590 or please someone tell me what it is associated with
    THANK YOU in Advatage
  • mon2
    • Dec 2019
    • 14284
    Re: La-c701p
    That is a large cap. To me, looks to be an 0805 smd size.
    • pippo_one
      • Aug 2010
      • 120
      • Vicenza
      Re: La-c701p
      it seems to me too, but how do I identify it in the schema eleytrico and associate the value?
      • mon2
        • Dec 2019
        • 14284
        Re: La-c701p
        This is a non-polarized ceramic cap.
        Use 1uf (or a bit higher will be ok) 0805 at 6v3 rating.
        Suggest X7R but X5R will be fine. This defines the capacitance over temperature changes.
        • pippo_one
          • Aug 2010
          • 120
          • Vicenza
          Re: La-c701p
          I have 10u 25volt ..what do you things?
          • mon2
            • Dec 2019
            • 14284
            Re: La-c701p
            Sure. Go for it. It will work fine.
            • eccerr0r
              DDR2 resistor packs... 0804?
              by eccerr0r
              Are those typical resistor packs on DDR2 modules 0804 (2010 metric?) 22Ω x 4?
              Wondering what I need to buy if I can't find a sacrificial board with one... which will be annoying if I only need one, just like buying 1 resistor, except I'd be buying 4...
              04-14-2021, 11:56 PM
            • pippo_one
              bios needed for MSI Modern 15A11M-217xit
              by pippo_one
              Hello everyone
              I have a Msi modern notebook 15A11M-217XIT-GG51135U8GXXDXX
              S/N:K2104N0063855 with mainb ms-15521 rev 1.0....that doesn't start, no LEDs on, black screen.
              I'll start by saying that I don't have the wiring diagram or even a boardview. I can't find it online. I tried to test some voltage in the mainb and found that there are 3.0/3.3 volts and 5 volts. No short found in all pcb
              so I think it has a BIOS problem
              I'll post the bios obtained from the maib...but I wasn't able (to avoid compromising the chip) to obtain the "EC" file...with my "EPZ2023"...
              02-28-2025, 03:39 AM
              DELL Inspiron 7577 Notebook 7000 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 7577 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7577 boardview and 7577 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 7577...
              09-06-2024, 07:10 AM
            • pippo_one
              la-b162p need Bios
              by pippo_one
              Hi
              I have a mainb LA-B162P (cpu i5 + nvidia gpu) which sometimes turns on and after a few seconds turns off and on again as a continuous loop. or it stays on expelling heat from the fan that runs normally, but in both cases always with the black screen both internal and external, sometimes I appreciate a backlight flash for a second in the internal monitor.
              i downloaded the schematic and i went to check all the voltages of the mainb and i'm ok, so i thought it was a problem with the bios ...
              Now I bought a new EZP2019 programmer and I am ready to program the bios, (I have...
              05-02-2021, 06:11 AM
            • pippo_one
              Acer TM8572
              by pippo_one
              Hi everyone, I need help.
              I have an Acer Tm8572 series, to be precise Tm8573tg-434g64mnkk
              installed bios version 1.27
              the notebook now doesn't turn on, but before reaching this point I had problems turning it on, sometimes after pressing the button it would load the Acer logo and then it would turn off.
              I opened and replaced the CMOS battery and from that moment on it no longer showed any signs of life...I got the bios from the CMOS (W25Q16) which I placed...but when I read the EC it tells me it's empty no file read (MIXC25L1606E i /o Nuvoton NPCE781LA0DX )
              mainb...
              01-05-2025, 03:35 AM
