PS4 fat has inconsistent signal after HDMI replacement
  • supravit2000
    • Aug 2021
    • 11
    • bulgaria
    Hi, guys!
    I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
    My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so I checked the hdmi fuse, which was blown - replaced it with a fuse from SAA-001 board (that one has BLOD). Still no picture, so I replaced the HDMI IC from that same board and 2 HDMI filters as well. Replaced one resistor and a diode too (I think), which I saw on a repair video by Andrew Paul. Then the signal was fine, played for half hour, all good.
    After a couple of weeks I turned the console on and there was the WLOD again. On safe mode it fired up, I changed the resolution to 1080i, since on 1080p there was no signal. The colors were weird, but picture was present. I tried another cable - with that one 1080p worked, but all the whites on the screen were with snowy artifacts as well as the left corner. So I hot-aired the HDMI ic in order to solder any loose joints, and this time it worked fine on 1080p. I thought it was finally OK, so reassembled the unit.
    However, after turning on the console, it would go blank screen for a minute or two, then the signal comes back. Works fine for a couple of hours, then goes black/no signal for good. After power off/on again, the same thing happens - the signal randomly drops couple of times, then comes back and cuts out properly after a while.
    I would really appreciate if somebody with proper knowledge/experience has any idea what causes this issue. Many thanks!
    https://drive.google.com/file/d/1HWN...6CKylK5ag/view
  • diif
    • Feb 2014
    • 6978
    • England
    Re: PS4 fat has inconsistent signal after HDMI replacement
    Check each pin is soldered well by giving them a little push.
    • CapLeaker
      Leaking Member
      • 8158
      try a can of air upside down and start freezing stuff.
      • supravit2000
        • Aug 2021
        • 11
        • bulgaria
        all the pins are solid, mate :/ I even have a HDMI tester and everything goes where it should on a male plug. 10x for the advice, though!
        @CapLeaker - I am not familiar with that freezing stuff, haven't got a clue what it's all about.. but thanks for checking!
        • supravit2000
          • Aug 2021
          • 11
          • bulgaria
          Thanks a million, mate! I've fixed it, thanks to your advice!
          For anybody having the same problem - it seems that the Panasonic HDMI ic had a pin loose. I nearly broke it when testing.. It's not that easy to spot a loose connection on the chip, so be careful.
          • diif
            • Feb 2014
            • 6978
            • England
            I'm glad you've found the issue.
            • jimbofz
              harwa 42 lcd tv no hdmi signal output
              by jimbofz
              theres no precise model number on the rear cover boards labelled as below
              Hi just been given this lcd tv,
              ive not come across this make before
              there is no o/p from hdmi .its fine with scart .
              good pic for its age
              the main board is 782 L42W17-690B
              cant find much info on google
              to enter service menu .bring up a/v menu ,then 2580
              but cant move to next page ,for options
              (i was hoping ther may be an option to switch on/off hdmi/dvi)
              the reason for this , is when hdmi is selected it says: no dvi signal
              not: no hdmi...
              01-06-2022, 05:57 AM
            • AstutePauciloquent
              Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
              by AstutePauciloquent
              Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
              I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
              11-23-2023, 11:02 PM
            • aliougm
              Marantz SR4003 AVR HDMI board issue, seeking for help
              by aliougm
              I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
              Connection as below:
              Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
              If I bypassed AVR then HDTV screen color be good.
              I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
              3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
              I replaced all...
              04-30-2022, 12:21 PM
            • Gigabyte_PL
              PS4 PRO - black screen, white light
              by Gigabyte_PL
              I have problem with my Playstation 4 PRO. After a long break, I turned on the console and tried to play game. Game started, but after a minute it froze the console and crashed to the main menu. I tried running another game and the same problem.
              Error returned: CE-34878-0 (I changed HDD)
              I updated the software in the console. I unplugged the console, put it aside for a week and now I want to turn it on but there is no image. The console lights up white, there is communication via HDMI with the monitor - but only a black screen (but it detects the...
              01-04-2024, 05:46 AM
            • Xristakis795
              samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
              by Xristakis795
              hi to all
              i have the above model ue40d5003
              the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
              when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
              when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
              Can you tell me from your experience...
              02-09-2023, 03:17 PM
