Identify resistor R802 PS4 Pro PSU
  • sikocan
    • Oct 2019
    • 344
    Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured.
    • 31055
    Re: Identify resistor R802 PS4 Pro PSU
    there is a similar looking circuit at r103
    that 7pin chip is well blasted though!!
    • lotas
      • Jan 2016
      • 4620
      • Russia
      They always have 10kOm resistors between the gate and the source.
      • gica69
        Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
        by gica69
        I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
        Resistor shows orange range silver gold and green lines.
        Thanks in adv...
        07-21-2025, 09:49 PM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • mitsu2k
        Can someone please help me identify this resistor?
        by mitsu2k
        This is out of a Pridiom mini split unit. It is the power board. This component is completely charred however I was able to get a photo from a good board.
        I know it is .015 ohms and 1% tolerance but that’s about it.
        Thank you!!...
        07-07-2025, 02:24 PM
